drivers/net: Eliminate useless code
The variable qdev is initialized twice to the same (side effect-free)
expression.  Drop one initialization.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
@forall@
idexpression *x;
identifier f!=ERR_PTR;
x = f(...)
... when != x
x = f(...,<+...x...+>,...)
* x = f(...)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/qla3xxx.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/net/qla3xxx.c b/drivers/net/qla3xxx.c
index f922294..4ef0afb 100644
--- a/drivers/net/qla3xxx.c
+++ b/drivers/net/qla3xxx.c
@@ -4087,7 +4087,6 @@ static void __devexit ql3xxx_remove(struct pci_dev *pdev)
 	struct ql3_adapter *qdev = netdev_priv(ndev);
 	unregister_netdev(ndev);
-	qdev = netdev_priv(ndev);
 	ql_disable_interrupts(qdev);
BtrLinux
Privacy Overview
