drivers:net: delete premature free_irq
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Free_irq is not needed if there has been no request_irq. Free_irq is
removed from both the probe and remove functions. The correct request_irq
and free_irq are found in the open and close functions.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e;
*e = platform_get_irq(...);
... when != request_irq(e,...)
*free_irq(e,...)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/ethernet/nuvoton/w90p910_ether.c | 11 ++---------
1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/drivers/net/ethernet/nuvoton/w90p910_ether.c b/drivers/net/ethernet/nuvoton/w90p910_ether.c
index dcfe58f..79645f7 100644
--- a/drivers/net/ethernet/nuvoton/w90p910_ether.c
+++ b/drivers/net/ethernet/nuvoton/w90p910_ether.c
@@ -1014,7 +1014,7 @@ static int w90p910_ether_probe(struct platform_device *pdev)
if (ether->rxirq < 0) {
dev_err(&pdev->dev, "failed to get ether rx irq\n");
error = -ENXIO;
- goto failed_free_txirq;
+ goto failed_free_io;
platform_set_drvdata(pdev, dev);
@@ -1023,7 +1023,7 @@ static int w90p910_ether_probe(struct platform_device *pdev)
if (IS_ERR(ether->clk)) {
dev_err(&pdev->dev, "failed to get ether clock\n");
error = PTR_ERR(ether->clk);
- goto failed_free_rxirq;
ether->rmiiclk = clk_get(&pdev->dev, "RMII");
@@ -1049,10 +1049,6 @@ failed_put_rmiiclk:
clk_put(ether->rmiiclk);
failed_put_clk:
clk_put(ether->clk);
-failed_free_rxirq:
- free_irq(ether->rxirq, pdev);
-failed_free_txirq:
- free_irq(ether->txirq, pdev);
failed_free_io:
iounmap(ether->reg);
failed_free_mem:
@@ -1075,9 +1071,6 @@ static int w90p910_ether_remove(struct platform_device *pdev)
release_mem_region(ether->res->start, resource_size(ether->res));
- free_irq(ether->txirq, dev);
- free_irq(ether->rxirq, dev);
del_timer_sync(ðer->check_timer);
free_netdev(dev); |
error = -ENXIO;
failed_put_clk:
-failed_free_rxirq:
-failed_free_txirq:
failed_free_io:
failed_free_mem:
free_netdev(dev);
