drivers/net: Adjust confusing if indentation
Outdent the code following the if.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r disable braces4@
position p1,p2;
statement S1,S2;
if (...) { ... }
if (...) S1@p1 S2@p2
@script:python@
p1 << r.p1;
p2 << r.p2;
if (p1[0].column == p2[0].column):
  cocci.print_main("branch",p1)
  cocci.print_secs("after",p2)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/net/cpmac.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/cpmac.c b/drivers/net/cpmac.c
index e1f6156..ac3985c 100644
--- a/drivers/net/cpmac.c
+++ b/drivers/net/cpmac.c
@@ -506,7 +506,7 @@ static int cpmac_poll(struct napi_struct *napi, int budget)
 					"restart rx from a descriptor that's "
 					"not free: %p\n",
 					priv->dev->name, restart);
-				goto fatal_error;
+			goto fatal_error;
 		cpmac_write(priv->regs, CPMAC_RX_PTR(0), restart->mapping);
BtrLinux
Privacy Overview
