drivers/mtd/nand: Use kzalloc
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
 if (x == NULL) S
-memset(x, 0, size);
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
 drivers/mtd/nand/s3c2410.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/nand/s3c2410.c b/drivers/mtd/nand/s3c2410.c
index dc02dcd..239aadf 100644
--- a/drivers/mtd/nand/s3c2410.c
+++ b/drivers/mtd/nand/s3c2410.c
@@ -929,14 +929,13 @@ static int s3c24xx_nand_probe(struct platform_device *pdev)
 	pr_debug("s3c2410_nand_probe(%p)\n", pdev);
-	info = kmalloc(sizeof(*info), GFP_KERNEL);
+	info = kzalloc(sizeof(*info), GFP_KERNEL);
 	if (info == NULL) {
 		dev_err(&pdev->dev, "no memory for flash info\n");
 		err = -ENOMEM;
 		goto exit_error;
-	memset(info, 0, sizeof(*info));
 	platform_set_drvdata(pdev, info);
 	spin_lock_init(&info->controller.lock);
@@ -994,15 +993,13 @@ static int s3c24xx_nand_probe(struct platform_device *pdev)
 	/* allocate our information */
 	size = nr_sets * sizeof(*info->mtds);
-	info->mtds = kmalloc(size, GFP_KERNEL);
+	info->mtds = kzalloc(size, GFP_KERNEL);
 	if (info->mtds == NULL) {
 		dev_err(&pdev->dev, "failed to allocate mtd storage\n");
 		err = -ENOMEM;
 		goto exit_error;
-	memset(info->mtds, 0, size);
 	/* initialise all possible chips */
 	nmtd = info->mtds;
BtrLinux
Privacy Overview
