drivers/mtd/maps: introduce missing kfree
Error handling code following a kmalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
 drivers/mtd/maps/physmap_of.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/maps/physmap_of.c b/drivers/mtd/maps/physmap_of.c
index 36dbcee..859664a 100644
--- a/drivers/mtd/maps/physmap_of.c
+++ b/drivers/mtd/maps/physmap_of.c
@@ -353,7 +353,7 @@ static int __devinit of_flash_probe(struct of_device *dev,
 				   &info->parts, 0);
 	if (err < 0) {
 		of_free_probes(part_probe_types);
-		return err;
+		goto err_out;
@@ -361,14 +361,14 @@ static int __devinit of_flash_probe(struct of_device *dev,
 	if (err == 0) {
 		err = of_mtd_parse_partitions(&dev->dev, dp, &info->parts);
 		if (err < 0)
-			return err;
+			goto err_out;
 #endif
 	if (err == 0) {
 		err = parse_obsolete_partitions(dev, info, dp);
 		if (err < 0)
-			return err;
+			goto err_out;
 	if (err > 0)
BtrLinux
Privacy Overview
