drivers/mtd: Use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
drivers/mtd/mtdchar.c | 11 +++--------
1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/mtdchar.c b/drivers/mtd/mtdchar.c
index 8bb5e4a..8b223c0 100644
--- a/drivers/mtd/mtdchar.c
+++ b/drivers/mtd/mtdchar.c
@@ -404,14 +404,9 @@ static int mtd_do_writeoob(struct file *file, struct mtd_info *mtd,
if (ops.ooboffs && ops.ooblen > (mtd->oobsize - ops.ooboffs))
return -EINVAL;
- ops.oobbuf = kmalloc(length, GFP_KERNEL);
- if (!ops.oobbuf)
- return -ENOMEM;
- if (copy_from_user(ops.oobbuf, ptr, length)) {
- kfree(ops.oobbuf);
- return -EFAULT;
+ ops.oobbuf = memdup_user(ptr, length);
+ if (IS_ERR(ops.oobbuf))
+ return PTR_ERR(ops.oobbuf);
start &= ~((uint64_t)mtd->oobsize - 1);
ret = mtd->write_oob(mtd, start, &ops); |
return -EINVAL;
- if (!ops.oobbuf)
- return -ENOMEM;
- return -EFAULT;
