drivers/mtd: Use kzalloc
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
 if (x == NULL) S
-memset(x, 0, size);
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
 drivers/mtd/lpddr/qinfo_probe.c     | 7 ++-----
 drivers/mtd/maps/ixp2000.c          | 3 +--
 drivers/mtd/maps/ixp4xx.c           | 3 +--
 drivers/mtd/maps/pxa2xx-flash.c     | 3 +--
 drivers/mtd/tests/mtd_pagetest.c    | 3 +--
 drivers/mtd/tests/mtd_readtest.c    | 3 +--
 drivers/mtd/tests/mtd_speedtest.c   | 3 +--
 drivers/mtd/tests/mtd_stresstest.c  | 3 +--
 drivers/mtd/tests/mtd_subpagetest.c | 3 +--
 9 files changed, 10 insertions(+), 21 deletions(-)
diff --git a/drivers/mtd/lpddr/qinfo_probe.c b/drivers/mtd/lpddr/qinfo_probe.c
index 79bf40f..dbfe17b 100644
--- a/drivers/mtd/lpddr/qinfo_probe.c
+++ b/drivers/mtd/lpddr/qinfo_probe.c
@@ -134,13 +134,12 @@ out:
 static int lpddr_chip_setup(struct map_info *map, struct lpddr_private *lpddr)
-	lpddr->qinfo = kmalloc(sizeof(struct qinfo_chip), GFP_KERNEL);
+	lpddr->qinfo = kzalloc(sizeof(struct qinfo_chip), GFP_KERNEL);
 	if (!lpddr->qinfo) {
 		printk(KERN_WARNING "%s: no memory for LPDDR qinfo structure\n",
 				map->name);
 		return 0;
-	memset(lpddr->qinfo, 0, sizeof(struct qinfo_chip));
 	/* Get the ManuID */
 	lpddr->ManufactId = CMDVAL(map_read(map, map->pfow_base + PFOW_MANUFACTURER_ID));
@@ -185,13 +184,11 @@ static struct lpddr_private *lpddr_probe_chip(struct map_info *map)
 	lpddr.numchips = 1;
 	numvirtchips = lpddr.numchips * lpddr.qinfo->HWPartsNum;
-	retlpddr = kmalloc(sizeof(struct lpddr_private) +
+	retlpddr = kzalloc(sizeof(struct lpddr_private) +
 			numvirtchips * sizeof(struct flchip), GFP_KERNEL);
 	if (!retlpddr)
 		return NULL;
-	memset(retlpddr, 0, sizeof(struct lpddr_private) +
-				numvirtchips * sizeof(struct flchip));
 	memcpy(retlpddr, &lpddr, sizeof(struct lpddr_private));
 	retlpddr->numchips = numvirtchips;
diff --git a/drivers/mtd/maps/ixp2000.c b/drivers/mtd/maps/ixp2000.c
index 1bdf0ee..9639d83 100644
--- a/drivers/mtd/maps/ixp2000.c
+++ b/drivers/mtd/maps/ixp2000.c
@@ -165,12 +165,11 @@ static int ixp2000_flash_probe(struct platform_device *dev)
 		return -EIO;
-	info = kmalloc(sizeof(struct ixp2000_flash_info), GFP_KERNEL);
+	info = kzalloc(sizeof(struct ixp2000_flash_info), GFP_KERNEL);
 	if(!info) {
 		err = -ENOMEM;
 		goto Error;
-	memset(info, 0, sizeof(struct ixp2000_flash_info));
 	platform_set_drvdata(dev, info);
diff --git a/drivers/mtd/maps/ixp4xx.c b/drivers/mtd/maps/ixp4xx.c
index 7513d90..e0a5e04 100644
--- a/drivers/mtd/maps/ixp4xx.c
+++ b/drivers/mtd/maps/ixp4xx.c
@@ -196,12 +196,11 @@ static int ixp4xx_flash_probe(struct platform_device *dev)
 			return err;
-	info = kmalloc(sizeof(struct ixp4xx_flash_info), GFP_KERNEL);
+	info = kzalloc(sizeof(struct ixp4xx_flash_info), GFP_KERNEL);
 	if(!info) {
 		err = -ENOMEM;
 		goto Error;
-	memset(info, 0, sizeof(struct ixp4xx_flash_info));
diff --git a/drivers/mtd/maps/pxa2xx-flash.c b/drivers/mtd/maps/pxa2xx-flash.c
index 91dc633..dd90880 100644
--- a/drivers/mtd/maps/pxa2xx-flash.c
+++ b/drivers/mtd/maps/pxa2xx-flash.c
@@ -63,11 +63,10 @@ static int __init pxa2xx_flash_probe(struct platform_device *pdev)
 	if (!res)
 		return -ENODEV;
-	info = kmalloc(sizeof(struct pxa2xx_flash_info), GFP_KERNEL);
+	info = kzalloc(sizeof(struct pxa2xx_flash_info), GFP_KERNEL);
 	if (!info)
 		return -ENOMEM;
-	memset(info, 0, sizeof(struct pxa2xx_flash_info));
 	info->map.name = (char *) flash->name;
 	info->map.bankwidth = flash->width;
 	info->map.phys = res->start;
diff --git a/drivers/mtd/tests/mtd_pagetest.c b/drivers/mtd/tests/mtd_pagetest.c
index 921a85d..6bc1b82 100644
--- a/drivers/mtd/tests/mtd_pagetest.c
+++ b/drivers/mtd/tests/mtd_pagetest.c
@@ -480,12 +480,11 @@ static int scan_for_bad_eraseblocks(void)
 	int i, bad = 0;
-	bbt = kmalloc(ebcnt, GFP_KERNEL);
+	bbt = kzalloc(ebcnt, GFP_KERNEL);
 	if (!bbt) {
 		printk(PRINT_PREF "error: cannot allocate memory\n");
 		return -ENOMEM;
-	memset(bbt, 0 , ebcnt);
 	printk(PRINT_PREF "scanning for bad eraseblocks\n");
 	for (i = 0; i < ebcnt; ++i) {
diff --git a/drivers/mtd/tests/mtd_readtest.c b/drivers/mtd/tests/mtd_readtest.c
index 7107fcc..afe71aa 100644
--- a/drivers/mtd/tests/mtd_readtest.c
+++ b/drivers/mtd/tests/mtd_readtest.c
@@ -141,12 +141,11 @@ static int scan_for_bad_eraseblocks(void)
 	int i, bad = 0;
 	if (!bbt) {
 		return -ENOMEM;
 	/* NOR flash does not implement block_isbad */
 	if (mtd->block_isbad == NULL)
diff --git a/drivers/mtd/tests/mtd_speedtest.c b/drivers/mtd/tests/mtd_speedtest.c
index 56ca62b..161feeb 100644
--- a/drivers/mtd/tests/mtd_speedtest.c
+++ b/drivers/mtd/tests/mtd_speedtest.c
@@ -295,12 +295,11 @@ static int scan_for_bad_eraseblocks(void)
 	int i, bad = 0;
 	if (!bbt) {
 		return -ENOMEM;
diff --git a/drivers/mtd/tests/mtd_stresstest.c b/drivers/mtd/tests/mtd_stresstest.c
index 3854afe..531625f 100644
--- a/drivers/mtd/tests/mtd_stresstest.c
+++ b/drivers/mtd/tests/mtd_stresstest.c
@@ -221,12 +221,11 @@ static int scan_for_bad_eraseblocks(void)
 	int i, bad = 0;
 	if (!bbt) {
 		return -ENOMEM;
diff --git a/drivers/mtd/tests/mtd_subpagetest.c b/drivers/mtd/tests/mtd_subpagetest.c
index 700237a..11204e8 100644
--- a/drivers/mtd/tests/mtd_subpagetest.c
+++ b/drivers/mtd/tests/mtd_subpagetest.c
@@ -354,12 +354,11 @@ static int scan_for_bad_eraseblocks(void)
 	int i, bad = 0;
 	if (!bbt) {
 		return -ENOMEM;
BtrLinux
Privacy Overview
