drivers/mtd: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
 drivers/mtd/mtdconcat.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/mtd/mtdconcat.c b/drivers/mtd/mtdconcat.c
index db6de74..7e07562 100644
--- a/drivers/mtd/mtdconcat.c
+++ b/drivers/mtd/mtdconcat.c
@@ -183,10 +183,9 @@ concat_writev(struct mtd_info *mtd, const struct kvec *vecs,
 	/* make a copy of vecs */
-	vecs_copy = kmalloc(sizeof(struct kvec) * count, GFP_KERNEL);
+	vecs_copy = kmemdup(vecs, sizeof(struct kvec) * count, GFP_KERNEL);
 	if (!vecs_copy)
 		return -ENOMEM;
-	memcpy(vecs_copy, vecs, sizeof(struct kvec) * count);
 	entry_low = 0;
 	for (i = 0; i < concat->num_subdev; i++) {
BtrLinux
Privacy Overview
