drivers/mmc: Move a dereference below a NULL test
In each case, if the NULL test is necessary, then the dereference should be
moved below the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
  ... when != E
      when != i
  if (E == NULL) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Signed-off-by: Pierre Ossman
 drivers/mmc/host/tmio_mmc.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/host/tmio_mmc.c b/drivers/mmc/host/tmio_mmc.c
index 95430b8..6a7a619 100644
--- a/drivers/mmc/host/tmio_mmc.c
+++ b/drivers/mmc/host/tmio_mmc.c
@@ -224,7 +224,7 @@ static inline void tmio_mmc_data_irq(struct tmio_mmc_host *host)
 	void __iomem *ctl = host->ctl;
 	struct mmc_data *data = host->data;
-	struct mmc_command *stop = data->stop;
+	struct mmc_command *stop;
 	host->data = NULL;
@@ -232,6 +232,7 @@ static inline void tmio_mmc_data_irq(struct tmio_mmc_host *host)
 		pr_debug("Spurious data end IRQ\n");
 		return;
+	stop = data->stop;
 	/* FIXME - return correct transfer count on errors */
 	if (!data->error)
BtrLinux
Privacy Overview
