drivers/misc: elide a non-zero test on a result that is never 0
The function thermal_cooling_device_register always returns either a valid
pointer or a value made with ERR_PTR, so a test for non-zero on the result
will always succeed.
The problem was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
@a@
expression E, E1;
statement S,S1;
position p;
E = thermal_cooling_device_register(...)
... when != E = E1
if@p (E) S else S1
@n@
position a.p;
expression E,E1;
statement S,S1;
E = NULL
... when != E = E1
if@p (E) S else S1
@depends on !n@
expression E;
statement S,S1;
position a.p;
* if@p (E)
  S else S1
Signed-off-by: Julia Lawall
Cc: Thomas Sujith
Cc: Len Brown
Cc: Zhang Rui
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/misc/intel_menlow.c | 24 +++++++++++-------------
 1 file changed, 11 insertions(+), 13 deletions(-)
diff --git a/drivers/misc/intel_menlow.c b/drivers/misc/intel_menlow.c
index 0c0bb30..80a1363 100644
--- a/drivers/misc/intel_menlow.c
+++ b/drivers/misc/intel_menlow.c
@@ -175,19 +175,17 @@ static int intel_menlow_memory_add(struct acpi_device *device)
 		goto end;
-	if (cdev) {
-		acpi_driver_data(device) = cdev;
-		result = sysfs_create_link(&device->dev.kobj,
-					&cdev->device.kobj, "thermal_cooling");
-		if (result)
-			goto unregister;
-		result = sysfs_create_link(&cdev->device.kobj,
-					&device->dev.kobj, "device");
-		if (result) {
-			sysfs_remove_link(&device->dev.kobj, "thermal_cooling");
-			goto unregister;
+	acpi_driver_data(device) = cdev;
+	result = sysfs_create_link(&device->dev.kobj,
+				&cdev->device.kobj, "thermal_cooling");
+	if (result)
+		goto unregister;
+	result = sysfs_create_link(&cdev->device.kobj,
+				&device->dev.kobj, "device");
+	if (result) {
+		sysfs_remove_link(&device->dev.kobj, "thermal_cooling");
+		goto unregister;
  end:
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
