drivers/message/i2o/exec-osm.c: add missing mutex_unlock
Add a mutex_unlock missing on the error path.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E1;
* mutex_lock(E1,...);
  <+... when != E1
  if (...) {
    ... when != E1
*   return ...;
* mutex_unlock(E1,...);
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/message/i2o/exec-osm.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/message/i2o/exec-osm.c b/drivers/message/i2o/exec-osm.c
index 06c655c..a3970e5 100644
--- a/drivers/message/i2o/exec-osm.c
+++ b/drivers/message/i2o/exec-osm.c
@@ -389,12 +389,16 @@ static int i2o_exec_lct_notify(struct i2o_controller *c, u32 change_ind)
 	dev = &c->pdev->dev;
 	if (i2o_dma_realloc(dev, &c->dlct,
-					le32_to_cpu(sb->expected_lct_size)))
+					le32_to_cpu(sb->expected_lct_size))) {
+		mutex_unlock(&c->lct_lock);
 		return -ENOMEM;
 	msg = i2o_msg_get_wait(c, I2O_TIMEOUT_MESSAGE_GET);
-	if (IS_ERR(msg))
+	if (IS_ERR(msg)) {
 		return PTR_ERR(msg);
 	msg->u.head[0] = cpu_to_le32(EIGHT_WORD_MSG_SIZE | SGL_OFFSET_6);
 	msg->u.head[1] = cpu_to_le32(I2O_CMD_LCT_NOTIFY << 24 | HOST_TID << 12 |
BtrLinux
Privacy Overview
