drivers/message: move dereference after NULL test
If the NULL test on dev->i2o_dev or i2o_dev is needed, then the dereference
should be after the NULL test.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
@match exists@
expression x, E;
identifier fld;
* x->fld
  ... when != \(x = E\|&x\)
* x == NULL
Signed-off-by: Julia Lawall
Cc: James Bottomley
Cc: Kashyap Desai
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/message/i2o/i2o_block.c | 3 ++-
 drivers/message/i2o/i2o_scsi.c  | 3 +--
 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/message/i2o/i2o_block.c b/drivers/message/i2o/i2o_block.c
index e6733bc..f0f1e66 100644
--- a/drivers/message/i2o/i2o_block.c
+++ b/drivers/message/i2o/i2o_block.c
@@ -727,7 +727,7 @@ static int i2o_block_transfer(struct request *req)
 	struct i2o_block_device *dev = req->rq_disk->private_data;
 	struct i2o_controller *c;
-	u32 tid = dev->i2o_dev->lct_data.tid;
+	u32 tid;
 	struct i2o_message *msg;
 	u32 *mptr;
 	struct i2o_block_request *ireq = req->special;
@@ -743,6 +743,7 @@ static int i2o_block_transfer(struct request *req)
 		goto exit;
+	tid = dev->i2o_dev->lct_data.tid;
 	c = dev->i2o_dev->iop;
 	msg = i2o_msg_get(c);
diff --git a/drivers/message/i2o/i2o_scsi.c b/drivers/message/i2o/i2o_scsi.c
index 3d45817..ea6b219 100644
--- a/drivers/message/i2o/i2o_scsi.c
+++ b/drivers/message/i2o/i2o_scsi.c
@@ -528,7 +528,6 @@ static int i2o_scsi_queuecommand(struct scsi_cmnd *SCpnt,
 	 *      Do the incoming paperwork
 	i2o_dev = SCpnt->device->hostdata;
-	c = i2o_dev->iop;
 	SCpnt->scsi_done = done;
@@ -538,7 +537,7 @@ static int i2o_scsi_queuecommand(struct scsi_cmnd *SCpnt,
 		done(SCpnt);
 		goto exit;
+	c = i2o_dev->iop;
 	tid = i2o_dev->lct_data.tid;
 	osm_debug("qcmd: Tid = %03x\n", tid);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
