drivers/macintosh/via-pmu.c: Added a missing iounmap
The error handling code should undo the ioremap as well.
The problem was detected using the following semantic match
(http://www.emn.fr/x-info/coccinelle/)
type T,T1,T2;
identifier E;
statement S;
expression x1,x2;
constant C;
int ret;
  T E;
* E = ioremap(...);
  if (E == NULL) S
  ... when != iounmap(E)
      when != if (E != NULL) { ... iounmap(E); ...}
      when != x1 = (T1)E
  if (...) {
        when != x2 = (T2)E
*   return;
*   return C;
*   return ret;
Signed-off-by: Julia Lawall
Cc: Johannes Berg
Cc: Olaf Hering
Cc: Benjamin Herrenschmidt
Cc: Paul Mackerras
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/macintosh/via-pmu.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/macintosh/via-pmu.c b/drivers/macintosh/via-pmu.c
index dc741d3..6123c70 100644
--- a/drivers/macintosh/via-pmu.c
+++ b/drivers/macintosh/via-pmu.c
@@ -2336,6 +2336,7 @@ powerbook_sleep_3400(void)
 	ret = pmac_suspend_devices();
 	if (ret) {
 		pbook_free_pci_save();
+		iounmap(mem_ctrl);
 		printk(KERN_ERR "Sleep rejected by devices\n");
 		return ret;
BtrLinux
Privacy Overview
