drivers/macintosh: Add missing of_node_put in therm_adt746x.c
Author: Nicolas Palix <npalix@diku.dk>
of_node_put is needed before discarding a value received from
of_find_node_by_name, eg in error handling code or when the device node is
no longer used.
The semantic match that catches the bug is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression struct device_node *n;
position p1, p2;
struct device_node *n1;
statement S;
identifier f;
expression E;
expression *ptr != NULL;
n@p1 = of_find_node_by_name(...)
if (!n) S
... when != of_node_put(n)
    when != n1 = f(n,...)
    when != E = n
    when any
    when strict
  return \(0\|<+...n...+>\|ptr\);
return@p2 ...;
  of_node_put(n);
  n1 = f(n,...)
  E = n
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s of_find_node_by_name %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Nicolas Palix
Signed-off-by: Julia Lawall
Acked-by: Stephen Rothwell
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/macintosh/therm_adt746x.c | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/macintosh/therm_adt746x.c b/drivers/macintosh/therm_adt746x.c
index 22bf981..82607ad 100644
--- a/drivers/macintosh/therm_adt746x.c
+++ b/drivers/macintosh/therm_adt746x.c
@@ -554,7 +554,7 @@ thermostat_init(void)
 	const u32 *prop;
 	int i = 0, offset = 0;
 	int err;
 	np = of_find_node_by_name(NULL, "fan");
 	if (!np)
 		return -ENODEV;
@@ -613,13 +613,13 @@ thermostat_init(void)
 	of_dev = of_platform_device_create(np, "temperatures", NULL);
+	of_node_put(np);
 	if (of_dev == NULL) {
 		printk(KERN_ERR "Can't register temperatures device !\n");
-		of_node_put(np);
 		return -ENODEV;
 	err = device_create_file(&of_dev->dev, &dev_attr_sensor1_temperature);
 	err |= device_create_file(&of_dev->dev, &dev_attr_sensor2_temperature);
 	err |= device_create_file(&of_dev->dev, &dev_attr_sensor1_limit);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
