drivers/isdn/mISDN: use ARRAY_SIZE
ARRAY_SIZE is more concise to use when the size of an array is divided by
the size of its type or the size of its first element.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@i@
#include
@depends on i using "paren.iso"@
type T;
T[] E;
- (sizeof(E)/sizeof(T))
+ ARRAY_SIZE(E)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: David S. Miller
 drivers/isdn/mISDN/dsp_hwec.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/isdn/mISDN/dsp_hwec.c b/drivers/isdn/mISDN/dsp_hwec.c
index eb892d9..806a997 100644
--- a/drivers/isdn/mISDN/dsp_hwec.c
+++ b/drivers/isdn/mISDN/dsp_hwec.c
@@ -43,7 +43,7 @@ static struct mISDN_dsp_element dsp_hwec_p = {
 	.free = NULL,
 	.process_tx = NULL,
 	.process_rx = NULL,
-	.num_args = sizeof(args) / sizeof(struct mISDN_dsp_element_arg),
+	.num_args = ARRAY_SIZE(args),
 	.args = args,
 struct mISDN_dsp_element *dsp_hwec = &dsp_hwec_p;
BtrLinux
Privacy Overview
