drivers/isdn/hardware/mISDN: move a dereference below a NULL test
In each case, if the NULL test is necessary, then the dereference should be
moved below the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
  ... when != E
      when != i
  if (E == NULL) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Karsten Keil
 drivers/isdn/hardware/mISDN/hfcmulti.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/isdn/hardware/mISDN/hfcmulti.c b/drivers/isdn/hardware/mISDN/hfcmulti.c
index 97f4708..595ba8e 100644
--- a/drivers/isdn/hardware/mISDN/hfcmulti.c
+++ b/drivers/isdn/hardware/mISDN/hfcmulti.c
@@ -3615,7 +3615,7 @@ hfcm_bctrl(struct mISDNchannel *ch, u_int cmd, void *arg)
 static void
 ph_state_change(struct dchannel *dch)
-	struct hfc_multi *hc = dch->hw;
+	struct hfc_multi *hc;
 	int ch, i;
 	if (!dch) {
@@ -3623,6 +3623,7 @@ ph_state_change(struct dchannel *dch)
 		    __func__);
 		return;
+	hc = dch->hw;
 	ch = dch->slot;
 	if (hc->type == 1) {
BtrLinux
Privacy Overview
