drivers/isdn/capi/kcapi.c: Adjust error handling code involving capi_ctr_put
After calling capi_ctr_get, error handling code should call capi_ctr_put.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r@
expression x,E;
statement S;
position p1,p2,p3;
if ((x = capi_ctr_get@p1(...)) == NULL || ...) S
... when != x
if (x == NULL || ...) S
if@p3 (...) { ... when != capi_ctr_put(x)
                  when != if (x) { ... capi_ctr_put(x); ...}
    return@p2 ...;
return x;
return 0;
x = E
E = x
capi_ctr_put(x)
@exists@
position r.p1,r.p2,r.p3;
expression x;
int ret != 0;
statement S;
* x = capi_ctr_get@p1(...)
* if@p3 (...)
  S
* return@p2 \(NULL\|ret\);
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: David S. Miller
 drivers/isdn/capi/kcapi.c | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/drivers/isdn/capi/kcapi.c b/drivers/isdn/capi/kcapi.c
index 75726ea..5360c4f 100644
--- a/drivers/isdn/capi/kcapi.c
+++ b/drivers/isdn/capi/kcapi.c
@@ -828,15 +828,18 @@ static int old_capi_manufacturer(unsigned int cmd, void __user *data)
 			return -ESRCH;
 		if (card->load_firmware == NULL) {
 			printk(KERN_DEBUG "kcapi: load: no load function\n");
+			capi_ctr_put(card);
 			return -ESRCH;
 		if (ldef.t4file.len <= 0) {
 			printk(KERN_DEBUG "kcapi: load: invalid parameter: length of t4file is %d ?\n", ldef.t4file.len);
 			return -EINVAL;
 		if (ldef.t4file.data == NULL) {
 			printk(KERN_DEBUG "kcapi: load: invalid parameter: dataptr is 0\n");
 			return -EINVAL;
@@ -849,6 +852,7 @@ static int old_capi_manufacturer(unsigned int cmd, void __user *data)
 		if (card->cardstate != CARD_DETECTED) {
 			printk(KERN_INFO "kcapi: load: contr=%d not in detect state\n", ldef.contr);
 			return -EBUSY;
 		card->cardstate = CARD_LOADING;
BtrLinux
Privacy Overview
