drivers/isdn: correct use of ! and &
In commit e6bafba5b4765a5a252f1b8d31cbf6d2459da337 ("wmi: (!x & y)
strikes again"), a bug was fixed that involved converting !x & y to !(x
& y).  The code below shows the same pattern, and thus should perhaps be
fixed in the same way.
This is not tested and clearly changes the semantics, so it is only
something to consider.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@@ expression E1,E2; @@
  !E1 & !E2
- !E1 & E2
+ !(E1 & E2)
Signed-off-by: Julia Lawall
Cc: Karsten Keil
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/isdn/i4l/isdn_ttyfax.c   | 3 ++-
 drivers/isdn/isdnloop/isdnloop.c | 6 +++---
 2 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/drivers/isdn/i4l/isdn_ttyfax.c b/drivers/isdn/i4l/isdn_ttyfax.c
index f93de4a..78f7660 100644
--- a/drivers/isdn/i4l/isdn_ttyfax.c
+++ b/drivers/isdn/i4l/isdn_ttyfax.c
@@ -906,7 +906,8 @@ isdn_tty_cmd_FCLASS2(char **p, modem_info * info)
 			sprintf(rs, "\r\n0-2");
 			isdn_tty_at_cout(rs, info);
 		} else {
-			if ((f->phase != ISDN_FAX_PHASE_D) || (!info->faxonline & 1))
+			if ((f->phase != ISDN_FAX_PHASE_D) ||
+			    (!(info->faxonline & 1)))
 				PARSE_ERROR1;
 			par = isdn_getnum(p);
 			if ((par < 0) || (par > 2))
diff --git a/drivers/isdn/isdnloop/isdnloop.c b/drivers/isdn/isdnloop/isdnloop.c
index 655ef9a..a335c85 100644
--- a/drivers/isdn/isdnloop/isdnloop.c
+++ b/drivers/isdn/isdnloop/isdnloop.c
@@ -1289,7 +1289,7 @@ isdnloop_command(isdn_ctrl * c, isdnloop_card * card)
 				break;
 		case ISDN_CMD_CLREAZ:
-				if (!card->flags & ISDNLOOP_FLAGS_RUNNING)
+				if (!(card->flags & ISDNLOOP_FLAGS_RUNNING))
 					return -ENODEV;
 				if (card->leased)
 					break;
@@ -1333,7 +1333,7 @@ isdnloop_command(isdn_ctrl * c, isdnloop_card * card)
 				break;
 		case ISDN_CMD_SETL3:
 					return -ENODEV;
 				return 0;
 		default:
@@ -1380,7 +1380,7 @@ if_writecmd(const u_char __user *buf, int len, int id, int channel)
 	isdnloop_card *card = isdnloop_findcard(id);
 	if (card) {
 			return -ENODEV;
 		return (isdnloop_writecmd(buf, len, 1, card));
BtrLinux
Privacy Overview
