drivers/ipack/devices/ipoctal.c: adjust duplicate test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive tests to the same location.  The code tested the result
of a previous allocation, that itself was already tested.  It is changed to
test the result of the most recent allocation.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@s exists@
local idexpression y;
expression x,e;
*if ( \(x == NULL\|IS_ERR(x)\|y != 0\) )
 { ... when forall
   return ...; }
... when != \(y = e\|y += e\|y -= e\|y |= e\|y &= e\|y++\|y--\|&y\)
    when != \(XT_GETPAGE(...,y)\|WMI_CMD_BUF(...)\)
 { ... when forall
   return ...; }
Signed-off-by: Julia Lawall
Cc: Samuel Iglesias Gonsalvez
 drivers/ipack/devices/ipoctal.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ipack/devices/ipoctal.c b/drivers/ipack/devices/ipoctal.c
index 93cbf9d..a2cf0f2 100644
--- a/drivers/ipack/devices/ipoctal.c
+++ b/drivers/ipack/devices/ipoctal.c
@@ -289,7 +289,7 @@ static int ipoctal_inst_slot(struct ipoctal *ipoctal, unsigned int bus_nr,
 	ipoctal->mem8_space =
 		devm_ioremap_nocache(&ipoctal->dev->dev,
 				     region->start, 0x8000);
-	if (!addr) {
+	if (!ipoctal->mem8_space) {
 		dev_err(&ipoctal->dev->dev,
 			"Unable to map slot [%d:%d] MEM8 space!\n",
 			bus_nr, slot);
BtrLinux
Privacy Overview
