drivers/iio/industrialio-event.c: eliminate possible double free
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The function __iio_add_event_config_attrs is only called once, by the
function iio_device_register_eventset. If the call fails,
iio_device_register_eventset calls __iio_remove_event_config_attrs. There
is thus no need for __iio_add_event_config_attrs to also call
__iio_remove_event_config_attrs on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r@
identifier f,free,a;
parameter list[n] ps;
type T;
expression e;
f(ps,T a,...) {
... when any
when != a = e
if(...) { ... free(a); ... return ...; }
... when any
identifier r.f,r.free;
expression x,a;
expression list[r.n] xs;
* x = f(xs,a,...);
if (...) { ... free(a); ... return ...; }
Signed-off-by: Julia Lawall
Signed-off-by: Jonathan Cameron
drivers/iio/industrialio-event.c | 7 +------
1 file changed, 1 insertion(+), 6 deletions(-)
diff --git a/drivers/iio/industrialio-event.c b/drivers/iio/industrialio-event.c
index 857e630..261cae0 100644
--- a/drivers/iio/industrialio-event.c
+++ b/drivers/iio/industrialio-event.c
@@ -350,15 +350,10 @@ static inline int __iio_add_event_config_attrs(struct iio_dev *indio_dev)
ret = iio_device_add_event_sysfs(indio_dev,
&indio_dev->channels[j]);
if (ret < 0)
- goto error_clear_attrs;
+ return ret;
attrcount += ret;
return attrcount;
-error_clear_attrs:
- __iio_remove_event_config_attrs(indio_dev);
- return ret;
static bool iio_check_for_dynamic_events(struct iio_dev *indio_dev) |
if (ret < 0)
+ return ret;
attrcount += ret;
return attrcount;
-error_clear_attrs:
- return ret;
