drivers/ide/cy82c693.c: Add missing pci_dev_put
Pci_get_slot calls pci_dev_get, so pci_dev_put is needed before leaving the
function in the case where pci_get_slot is locally used.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
local idexpression x;
expression e;
*x = pci_get_slot(...)
... when != true x == NULL
    when != pci_dev_put(x)
    when != e = x
    when != if (x != NULL) {<+... pci_dev_put(x); ...+>}
*return ...;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/ide/cy82c693.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/drivers/ide/cy82c693.c b/drivers/ide/cy82c693.c
index 3be60da..67cbcfa 100644
--- a/drivers/ide/cy82c693.c
+++ b/drivers/ide/cy82c693.c
@@ -141,6 +141,8 @@ static void cy82c693_set_pio_mode(ide_hwif_t *hwif, ide_drive_t *drive)
 		pci_write_config_byte(dev, CY82_IDE_SLAVE_IOW, time_16);
 		pci_write_config_byte(dev, CY82_IDE_SLAVE_8BIT, time_8);
+	if (hwif->index > 0)
+		pci_dev_put(dev);
 static void __devinit init_iops_cy82c693(ide_hwif_t *hwif)
