drivers/ide/{cs5530.c,sc1200.c}: Move a dereference below a NULL test
In each case, if the NULL test is necessary, then the dereference should be
moved below the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
type T;
expression E;
identifier i,fld;
statement S;
- T i = E->fld;
+ T i;
  ... when != E
      when != i
  if (E == NULL) S
+ i = E->fld;
Signed-off-by: Julia Lawall
Acked-by: Sergei Shtylyov
Signed-off-by: Bartlomiej Zolnierkiewicz
 drivers/ide/cs5530.c | 3 ++-
 drivers/ide/sc1200.c | 3 ++-
 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/ide/cs5530.c b/drivers/ide/cs5530.c
index 53f079c..d8ede85 100644
--- a/drivers/ide/cs5530.c
+++ b/drivers/ide/cs5530.c
@@ -81,11 +81,12 @@ static u8 cs5530_udma_filter(ide_drive_t *drive)
 	ide_hwif_t *hwif = drive->hwif;
 	ide_drive_t *mate = ide_get_pair_dev(drive);
-	u16 *mateid = mate->id;
+	u16 *mateid;
 	u8 mask = hwif->ultra_mask;
 	if (mate == NULL)
 		goto out;
+	mateid = mate->id;
 	if (ata_id_has_dma(mateid) && __ide_dma_bad_drive(mate) == 0) {
 		if ((mateid[ATA_ID_FIELD_VALID] & 4) &&
diff --git a/drivers/ide/sc1200.c b/drivers/ide/sc1200.c
index f1a8758..ec7f766 100644
--- a/drivers/ide/sc1200.c
+++ b/drivers/ide/sc1200.c
@@ -104,11 +104,12 @@ static u8 sc1200_udma_filter(ide_drive_t *drive)
+	u16 *mateid;
 	if (mate == NULL)
 		goto out;
 		if ((mateid[ATA_ID_FIELD_VALID] & 4) && |
+	u16 *mateid;
 	if (mate == NULL)
 		goto out;
+	u16 *mateid;
 	if (mate == NULL)
 		goto out;
