drivers/gpu/drm: Use kmemdup
Use kmemdup when some other buffer is immediately copied into the
allocated region.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression from,to,size,flag;
statement S;
-  to = \(kmalloc\|kzalloc\)(size,flag);
+  to = kmemdup(from,size,flag);
   if (to==NULL || ...) S
-  memcpy(to, from, size);
Signed-off-by: Julia Lawall
Signed-off-by: Dave Airlie
 drivers/gpu/drm/nouveau/nouveau_grctx.c | 6 ++----
 drivers/gpu/drm/radeon/radeon_bios.c    | 3 +--
 2 files changed, 3 insertions(+), 6 deletions(-)
diff --git a/drivers/gpu/drm/nouveau/nouveau_grctx.c b/drivers/gpu/drm/nouveau/nouveau_grctx.c
index 32f0e49..f731c5f 100644
--- a/drivers/gpu/drm/nouveau/nouveau_grctx.c
+++ b/drivers/gpu/drm/nouveau/nouveau_grctx.c
@@ -68,13 +68,12 @@ nouveau_grctx_prog_load(struct drm_device *dev)
 			return ret;
-		pgraph->ctxprog = kmalloc(fw->size, GFP_KERNEL);
+		pgraph->ctxprog = kmemdup(fw->data, fw->size, GFP_KERNEL);
 		if (!pgraph->ctxprog) {
 			NV_ERROR(dev, "OOM copying ctxprog\n");
 			release_firmware(fw);
 			return -ENOMEM;
-		memcpy(pgraph->ctxprog, fw->data, fw->size);
 		cp = pgraph->ctxprog;
 		if (le32_to_cpu(cp->signature) != 0x5043564e ||
@@ -97,14 +96,13 @@ nouveau_grctx_prog_load(struct drm_device *dev)
 			return ret;
-		pgraph->ctxvals = kmalloc(fw->size, GFP_KERNEL);
+		pgraph->ctxvals = kmemdup(fw->data, fw->size, GFP_KERNEL);
 		if (!pgraph->ctxvals) {
 			NV_ERROR(dev, "OOM copying ctxvals\n");
 			nouveau_grctx_fini(dev);
 			return -ENOMEM;
-		memcpy(pgraph->ctxvals, fw->data, fw->size);
 		cv = (void *)pgraph->ctxvals;
 		if (le32_to_cpu(cv->signature) != 0x5643564e ||
diff --git a/drivers/gpu/drm/radeon/radeon_bios.c b/drivers/gpu/drm/radeon/radeon_bios.c
index 8ad71f7..fbba938 100644
--- a/drivers/gpu/drm/radeon/radeon_bios.c
+++ b/drivers/gpu/drm/radeon/radeon_bios.c
@@ -85,12 +85,11 @@ static bool radeon_read_bios(struct radeon_device *rdev)
 		pci_unmap_rom(rdev->pdev, bios);
 		return false;
-	rdev->bios = kmalloc(size, GFP_KERNEL);
+	rdev->bios = kmemdup(bios, size, GFP_KERNEL);
 	if (rdev->bios == NULL) {
 		return false;
-	memcpy(rdev->bios, bios, size);
 	return true;
BtrLinux
Privacy Overview
