drivers/gpio/gpio-pxa.c: use clk_prepare_enable and clk_disable_unprepare
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Clk_prepare_enable and clk_disable_unprepare combine clk_prepare and
clk_enable, and clk_disable and clk_unprepare. They make the code more
concise, and ensure that clk_unprepare is called when clk_enable fails.
A simplified version of the semantic patch that introduces calls to these
functions is as follows: (http://coccinelle.lip6.fr/)
expression e;
- clk_prepare(e);
- clk_enable(e);
+ clk_prepare_enable(e);
expression e;
- clk_disable(e);
- clk_unprepare(e);
+ clk_disable_unprepare(e);
Signed-off-by: Julia Lawall
Signed-off-by: Linus Walleij
drivers/gpio/gpio-pxa.c | 9 +--------
1 file changed, 1 insertion(+), 8 deletions(-)
diff --git a/drivers/gpio/gpio-pxa.c b/drivers/gpio/gpio-pxa.c
index 9cac88a..528de0f 100644
--- a/drivers/gpio/gpio-pxa.c
+++ b/drivers/gpio/gpio-pxa.c
@@ -620,19 +620,12 @@ static int __devinit pxa_gpio_probe(struct platform_device *pdev)
iounmap(gpio_reg_base);
return PTR_ERR(clk);
- ret = clk_prepare(clk);
+ ret = clk_prepare_enable(clk);
if (ret) {
clk_put(clk);
return ret;
- ret = clk_enable(clk);
- if (ret) {
- clk_unprepare(clk);
- clk_put(clk);
- iounmap(gpio_reg_base);
- return ret;
/* Initialize GPIO chips */
info = dev_get_platdata(&pdev->dev); |
if (ret) {
clk_put(clk);
return ret;
- if (ret) {
- clk_put(clk);
- return ret;
