Author: Julia Lawall <Julia.Lawall@lip6.fr>
Remove unneeded error handling on the result of a call to
platform_get_resource when the value is passed to devm_ioremap_resource.
Move the call to platform_get_resource adjacent to the call to
devm_ioremap_resource to make the connection between them more clear.
A simplified version of the semantic patch that makes this change is as
follows: (http://coccinelle.lip6.fr/)
expression pdev,res,n,e,e1;
expression ret != 0;
identifier l;
- res = platform_get_resource(pdev, IORESOURCE_MEM, n);
... when != res
- if (res == NULL) { ... \(goto l;\|return ret;\) }
... when != res
+ res = platform_get_resource(pdev, IORESOURCE_MEM, n);
e = devm_ioremap_resource(e1, res);
Signed-off-by: Julia Lawall
Acked-by: Viresh Kumar
Signed-off-by: Linus Walleij
drivers/gpio/gpio-mvebu.c | 7 +------
drivers/gpio/gpio-spear-spics.c | 7 +------
2 files changed, 2 insertions(+), 12 deletions(-)
diff --git a/drivers/gpio/gpio-mvebu.c b/drivers/gpio/gpio-mvebu.c
index 80ad35e..3c3321f 100644
--- a/drivers/gpio/gpio-mvebu.c
+++ b/drivers/gpio/gpio-mvebu.c
@@ -566,12 +566,6 @@ static int mvebu_gpio_probe(struct platform_device *pdev)
else
soc_variant = MVEBU_GPIO_SOC_VARIANT_ORION;
- res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
- if (!res) {
- dev_err(&pdev->dev, "Cannot get memory resource\n");
- return -ENODEV;
mvchip = devm_kzalloc(&pdev->dev, sizeof(struct mvebu_gpio_chip), GFP_KERNEL);
if (!mvchip) {
dev_err(&pdev->dev, "Cannot allocate memory\n");
@@ -611,6 +605,7 @@ static int mvebu_gpio_probe(struct platform_device *pdev)
mvchip->chip.dbg_show = mvebu_gpio_dbg_show;
spin_lock_init(&mvchip->lock);
+ res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
mvchip->membase = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(mvchip->membase))
return PTR_ERR(mvchip->membase);
diff --git a/drivers/gpio/gpio-spear-spics.c b/drivers/gpio/gpio-spear-spics.c
index 7a4bf7c..e9a0415 100644
--- a/drivers/gpio/gpio-spear-spics.c
+++ b/drivers/gpio/gpio-spear-spics.c
@@ -128,18 +128,13 @@ static int spics_gpio_probe(struct platform_device *pdev)
struct resource *res;
int ret;
- if (!res) {
- dev_err(&pdev->dev, "invalid IORESOURCE_MEM\n");
- return -EBUSY;
spics = devm_kzalloc(&pdev->dev, sizeof(*spics), GFP_KERNEL);
if (!spics) {
dev_err(&pdev->dev, "memory allocation fail\n");
return -ENOMEM;
spics->base = devm_ioremap_resource(&pdev->dev, res);
if (IS_ERR(spics->base))
return PTR_ERR(spics->base); |
else
- if (!res) {
- return -ENODEV;
if (!mvchip) {
int ret;
- if (!res) {
- return -EBUSY;
if (!spics) {
return -ENOMEM;
