drivers/dma: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Set the return variable to an error code as done elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Vinod Koul
 drivers/dma/cppi41.c      | 4 +++-
 drivers/dma/ppc4xx/adma.c | 1 +
 2 files changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/dma/cppi41.c b/drivers/dma/cppi41.c
index c29dacf..c18aebf 100644
--- a/drivers/dma/cppi41.c
+++ b/drivers/dma/cppi41.c
@@ -972,8 +972,10 @@ static int cppi41_dma_probe(struct platform_device *pdev)
 		goto err_chans;
 	irq = irq_of_parse_and_map(dev->of_node, 0);
-	if (!irq)
+	if (!irq) {
+		ret = -EINVAL;
 		goto err_irq;
 	cppi_writel(USBSS_IRQ_PD_COMP, cdd->usbss_mem + USBSS_IRQ_ENABLER);
diff --git a/drivers/dma/ppc4xx/adma.c b/drivers/dma/ppc4xx/adma.c
index 8da48c6..f9e5c0a 100644
--- a/drivers/dma/ppc4xx/adma.c
+++ b/drivers/dma/ppc4xx/adma.c
@@ -4139,6 +4139,7 @@ static int ppc440spe_adma_probe(struct platform_device *ofdev)
 	regs = ioremap(res.start, resource_size(&res));
 	if (!regs) {
 		dev_err(&ofdev->dev, "failed to ioremap regs!\n");
+		ret = -ENOMEM;
 		goto err_regs_alloc;
BtrLinux
Privacy Overview
