drivers/char/tlclk.c: fix error return code
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
    when != ret = e3
*if (x == NULL || ...)
  ... when != ret = e4
*  return ret;
Signed-off-by: Julia Lawall
Acked-by: Mark Gross
Cc: Arnd Bergmann
Signed-off-by: Andrew Morton
 drivers/char/tlclk.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/drivers/char/tlclk.c b/drivers/char/tlclk.c
index ce29e7c..e95e0ab 100644
--- a/drivers/char/tlclk.c
+++ b/drivers/char/tlclk.c
@@ -784,8 +784,10 @@ static int __init tlclk_init(void)
 	tlclk_major = ret;
 	alarm_events = kzalloc( sizeof(struct tlclk_alarms), GFP_KERNEL);
-	if (!alarm_events)
+	if (!alarm_events) {
+		ret = -ENOMEM;
 		goto out1;
 	/* Read telecom clock IRQ number (Set by BIOS) */
 	if (!request_region(TLCLK_BASE, 8, "telco_clock")) {
