drivers/char/ppdev.c: put gotten port value
parport_find_number() calls parport_get_port() on its result, so there
should be a corresponding call to parport_put_port() before dropping the
reference. Similar code is found in the function register_device() in the
same file.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@exists@
local idexpression struct parport * x;
expression ra,rr;
statement S1,S2;
x = parport_find_number(...)
... when != x = rr
when any
when != parport_put_port(x,...)
when != if (...) { ... parport_put_port(x,...) ...}
if(<+...x...+>) S1 else S2
if(...) { ... when != x = ra
when forall
*return...;
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
drivers/char/ppdev.c | 1 +
1 file changed, 1 insertion(+)
diff --git a/drivers/char/ppdev.c b/drivers/char/ppdev.c
index f176dba..3fcf80f 100644
--- a/drivers/char/ppdev.c
+++ b/drivers/char/ppdev.c
@@ -457,6 +457,7 @@ static int pp_do_ioctl(struct file *file, unsigned int cmd, unsigned long arg)
return -ENODEV;
modes = port->modes;
+ parport_put_port(port);
if (copy_to_user (argp, &modes, sizeof (modes))) {
return -EFAULT;
return -ENODEV;
return -EFAULT;
