drivers/char/mmtimer.c: Remove useless kfree
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
                        when != e = e1
                        when != e += e1
                        when != e -= e1
                        when != ++e
                        when != --e
                        when != e++
                        when != e--
                        when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
Signed-off-by: Peter Senna Tschudin
 drivers/char/mmtimer.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/char/mmtimer.c b/drivers/char/mmtimer.c
index 33dc229..3d6c067 100644
--- a/drivers/char/mmtimer.c
+++ b/drivers/char/mmtimer.c
@@ -826,7 +826,7 @@ static int __init mmtimer_init(void)
 	/* Allocate list of node ptrs to mmtimer_t's */
 	timers = kzalloc(sizeof(struct mmtimer_node)*maxn, GFP_KERNEL);
-	if (timers == NULL) {
+	if (!timers) {
 		printk(KERN_ERR "%s: failed to allocate memory for device\n",
 				MMTIMER_NAME);
 		goto out3;
@@ -848,7 +848,6 @@ static int __init mmtimer_init(void)
 	return 0;
 out3:
-	kfree(timers);
 	misc_deregister(&mmtimer_miscdev);
 out2:
 	free_irq(SGI_MMTIMER_VECTOR, NULL);
