drivers/char/mmtimer.c: eliminate useless code
The variable x is initialized twice to the same (side effect-free)
expression.  Drop one initialization.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
@forall@
idexpression *x;
identifier f!=ERR_PTR;
x = f(...)
... when != x
x = f(...,<+...x...+>,...)
* x = f(...)
Stefan observed:
  The next x = rb_entry(mn->next, struct mmtimer, list); is preceded by a
  test whether mn->next is NULL.
  Unless that test is redundant too, your patch fixes a potential NULL
  pointer dereference, introduced by commit cbacdd95 "SGI Altix mmtimer:
  allow larger number of timers per node" in 2.6.26.
Signed-off-by: Julia Lawall
Cc: Stefan Richter
Cc: Dimitri Sivanich
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/char/mmtimer.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/char/mmtimer.c b/drivers/char/mmtimer.c
index 918711a..04fd0d8 100644
--- a/drivers/char/mmtimer.c
+++ b/drivers/char/mmtimer.c
@@ -546,7 +546,7 @@ static void mmtimer_tasklet(unsigned long data)
 	int nodeid = data;
 	struct mmtimer_node *mn = &timers[nodeid];
-	struct mmtimer *x = rb_entry(mn->next, struct mmtimer, list);
+	struct mmtimer *x;
 	struct k_itimer *t;
 	unsigned long flags;
BtrLinux
Privacy Overview
