drivers/char/hw_random/octeon-rng.c: drop frees of devm allocated data
Author: Julia Lawall <Julia.Lawall@lip6.fr>
devm_kfree and devm_iounmap should not have to be explicitly used.
The semantic patch that fixes this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x,d;
x = devm_kzalloc(...)
?-devm_kfree(d,x);
Signed-off-by: Julia Lawall
Signed-off-by: Herbert Xu
drivers/char/hw_random/octeon-rng.c | 17 +++++------------
1 file changed, 5 insertions(+), 12 deletions(-)
diff --git a/drivers/char/hw_random/octeon-rng.c b/drivers/char/hw_random/octeon-rng.c
index 0943edc..5c34c09 100644
--- a/drivers/char/hw_random/octeon-rng.c
+++ b/drivers/char/hw_random/octeon-rng.c
@@ -75,42 +75,35 @@ static int __devinit octeon_rng_probe(struct platform_device *pdev)
res_ports = platform_get_resource(pdev, IORESOURCE_MEM, 0);
if (!res_ports)
- goto err_ports;
+ return -ENOENT;
res_result = platform_get_resource(pdev, IORESOURCE_MEM, 1);
if (!res_result)
- goto err_ports;
+ return -ENOENT;
rng->control_status = devm_ioremap_nocache(&pdev->dev,
res_ports->start,
sizeof(u64));
if (!rng->control_status)
- goto err_ports;
+ return -ENOENT;
rng->result = devm_ioremap_nocache(&pdev->dev,
res_result->start,
sizeof(u64));
if (!rng->result)
- goto err_r;
+ return -ENOENT;
rng->ops = ops;
dev_set_drvdata(&pdev->dev, &rng->ops);
ret = hwrng_register(&rng->ops);
if (ret)
- goto err;
+ return -ENOENT;
dev_info(&pdev->dev, "Octeon Random Number Generator\n");
return 0;
-err:
- devm_iounmap(&pdev->dev, rng->control_status);
-err_r:
- devm_iounmap(&pdev->dev, rng->result);
-err_ports:
- devm_kfree(&pdev->dev, rng);
- return -ENOENT;
static int __exit octeon_rng_remove(struct platform_device *pdev) |
if (!res_ports)
- goto err_ports;
+ return -ENOENT;
if (!res_result)
- goto err_ports;
+ return -ENOENT;
res_ports->start,
sizeof(u64));
- goto err_ports;
+ return -ENOENT;
res_result->start,
sizeof(u64));
if (!rng->result)
- goto err_r;
+ return -ENOENT;
rng->ops = ops;
if (ret)
- goto err;
+ return -ENOENT;
return 0;
-err:
-err_r:
-err_ports:
- return -ENOENT;
