drivers/char/ds1286.c: use time_before, time_before_eq, etc
The functions time_before, time_before_eq, time_after, and time_after_eq
are more robust for comparing jiffies against other values.
A simplified version of the semantic patch making this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ change_compare_np @
expression E;
- jiffies <= E
+ time_before_eq(jiffies,E)
- jiffies >= E
+ time_after_eq(jiffies,E)
- jiffies < E
+ time_before(jiffies,E)
- jiffies > E
+ time_after(jiffies,E)
@ include depends on change_compare_np @
#include
@ no_include depends on !include && change_compare_np @
  #include
+ #include
Signed-off-by: Julia Lawall
Cc: Jiri Slaby
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/char/ds1286.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/char/ds1286.c b/drivers/char/ds1286.c
index 59146e3..ea35ab2 100644
--- a/drivers/char/ds1286.c
+++ b/drivers/char/ds1286.c
@@ -39,6 +39,7 @@
 #include <linux/spinlock.h>
 #include <linux/bcd.h>
 #include <linux/proc_fs.h>
+#include <linux/jiffies.h>
 #include <asm/uaccess.h>
 #include <asm/system.h>
@@ -451,7 +452,7 @@ static void ds1286_get_time(struct rtc_time *rtc_tm)
 	if (ds1286_is_updating() != 0)
-		while (jiffies - uip_watchdog < 2*HZ/100)
+		while (time_before(jiffies, uip_watchdog + 2*HZ/100))
 			barrier();
BtrLinux
Privacy Overview
