drivers/char/amiserial.c: add missing local_irq_restore
rs_init() is failing to restore interrupts on two error paths, and is
incorrectly calling tty_unregister_driver() with local interrupts
disabled.
Fix these things by disabling interrupts later, after the reauest_irq()
calls.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@r exists@
expression E1;
identifier f;
f (...) { <+...
* local_irq_save (E1,...);
... when != E1
* return ...;
[akpm@linux-foundation.org: reimplement the fix]
Signed-off-by: Julia Lawall
Cc: Thadeu Lima de Souza Cascardo
Cc: Greg KH
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 drivers/char/amiserial.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/char/amiserial.c b/drivers/char/amiserial.c
index 6c32fbf..56b2767 100644
--- a/drivers/char/amiserial.c
+++ b/drivers/char/amiserial.c
@@ -2021,8 +2021,6 @@ static int __init rs_init(void)
 	state->baud_base = amiga_colorclock;
 	state->xmit_fifo_size = 1;
-	local_irq_save(flags);
 	/* set ISRs, and then disable the rx interrupts */
 	error = request_irq(IRQ_AMIGA_TBE, ser_tx_int, 0, "serial TX", state);
 	if (error)
@@ -2033,6 +2031,8 @@ static int __init rs_init(void)
 	if (error)
 		goto fail_free_irq;
+	local_irq_save(flags);
 	/* turn off Rx and Tx interrupts */
 	custom.intena = IF_RBF | IF_TBE;
 	mb();
BtrLinux
Privacy Overview
