drivers/char/agp/parisc-agp.c: eliminate memory leak
alloc_pci_dev allocates some memory, so that memory should be freed before
leaving the function in an error case.
A simplified version of the semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
@r exists@
local idexpression x;
expression E;
identifier f1;
iterator I;
x = alloc_pci_dev(...);
<... when != x
     when != true (x == NULL || ...)
     when != if (...) { <+...x...+> }
     when != I (...) { <+...x...+> }
 x == NULL
 x == E
 x->f1
* return ...;
Signed-off-by: Julia Lawall
Dan Carpenter
Dave Airlie
Cc: Helge Deller
Cc: "James E.J. Bottomley"
Signed-off-by: Andrew Morton
Signed-off-by: Kyle McMartin
 drivers/char/agp/parisc-agp.c | 4 ++++
 1 file changed, 4 insertions(+)
diff --git a/drivers/char/agp/parisc-agp.c b/drivers/char/agp/parisc-agp.c
index 1c12921..17e380f 100644
--- a/drivers/char/agp/parisc-agp.c
+++ b/drivers/char/agp/parisc-agp.c
@@ -358,8 +358,12 @@ parisc_agp_setup(void __iomem *ioc_hpa, void __iomem *lba_hpa)
 	bridge->dev = fake_bridge_dev;
 	error = agp_add_bridge(bridge);
+	if (error)
+		goto fail;
+	return 0;
 fail:
+	kfree(fake_bridge_dev);
 	return error;
BtrLinux
Privacy Overview
