drivers/block/drbd: Correct NULL test
Test the just-allocated value for NULL rather than some other value.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,y;
statement S;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
if ((x) == NULL) S
if (
-   y
+   x
       == NULL)
 S
Signed-off-by: Julia Lawall
Signed-off-by: Philipp Reisner
 drivers/block/drbd/drbd_receiver.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/block/drbd/drbd_receiver.c b/drivers/block/drbd/drbd_receiver.c
index a6d266e..dbd4519 100644
--- a/drivers/block/drbd/drbd_receiver.c
+++ b/drivers/block/drbd/drbd_receiver.c
@@ -3945,7 +3945,7 @@ static int drbd_do_auth(struct drbd_conf *mdev)
 	right_response = kmalloc(resp_size, GFP_NOIO);
-	if (response == NULL) {
+	if (right_response == NULL) {
 		dev_err(DEV, "kmalloc of right_response failed\n");
 		rv = 0;
 		goto fail;
