drivers/block: use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.  Some checkpatch cleanups in nearby code.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Cc: Chirag Kantharia
Signed-off-by: Andrew Morton
Signed-off-by: Jens Axboe
 drivers/block/cpqarray.c | 32 ++++++++++----------------------
 1 file changed, 10 insertions(+), 22 deletions(-)
diff --git a/drivers/block/cpqarray.c b/drivers/block/cpqarray.c
index 28937b6..9473215 100644
--- a/drivers/block/cpqarray.c
+++ b/drivers/block/cpqarray.c
@@ -1255,17 +1255,11 @@ static int ida_ctlr_ioctl(ctlr_info_t *h, int dsk, ida_ioctl_t *io)
 	/* Pre submit processing */
 	switch(io->cmd) {
 	case PASSTHRU_A:
-		p = kmalloc(io->sg[0].size, GFP_KERNEL);
-		if (!p)
-			error = -ENOMEM;
-			cmd_free(h, c, 0);
-			return(error);
-		if (copy_from_user(p, io->sg[0].addr, io->sg[0].size)) {
-			kfree(p);
-			return -EFAULT;
+		p = memdup_user(io->sg[0].addr, io->sg[0].size);
+		if (IS_ERR(p)) {
+			error = PTR_ERR(p);
+			cmd_free(h, c, 0);
+			return error;
 		c->req.hdr.blk = pci_map_single(h->pci_dev, &(io->c),
 				sizeof(ida_ioctl_t),
@@ -1296,18 +1290,12 @@ static int ida_ctlr_ioctl(ctlr_info_t *h, int dsk, ida_ioctl_t *io)
 	case DIAG_PASS_THRU:
 	case COLLECT_BUFFER:
 	case WRITE_FLASH_ROM:
-		if (!p)
-                        error = -ENOMEM;
-                        return(error);
+		if (IS_ERR(p)) {
+			return error;
-			kfree(p);
-			return -EFAULT;
 		c->req.sg[0].size = io->sg[0].size;
 		c->req.sg[0].addr = pci_map_single(h->pci_dev, p,
 			c->req.sg[0].size, PCI_DMA_BIDIRECTIONAL);
BtrLinux
Privacy Overview
