 drivers/block/cciss.c    | 8 ++++----
 drivers/block/cpqarray.c | 2 +-
 drivers/block/floppy.c   | 8 ++++----
 3 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/block/cciss.c b/drivers/block/cciss.c
index b73116e..1e1f915 100644
--- a/drivers/block/cciss.c
+++ b/drivers/block/cciss.c
@@ -3460,8 +3460,8 @@ static int __devinit cciss_init_one(struct pci_dev *pdev,
 	       hba[i]->intr[SIMPLE_MODE_INT], dac ? "" : " not");
 	hba[i]->cmd_pool_bits =
-	    kmalloc(((hba[i]->nr_cmds + BITS_PER_LONG -
-		      1) / BITS_PER_LONG) * sizeof(unsigned long), GFP_KERNEL);
+	    kmalloc(DIV_ROUND_UP(hba[i]->nr_cmds, BITS_PER_LONG)
+			* sizeof(unsigned long), GFP_KERNEL);
 	hba[i]->cmd_pool = (CommandList_struct *)
 	    pci_alloc_consistent(hba[i]->pdev,
 		    hba[i]->nr_cmds * sizeof(CommandList_struct),
@@ -3493,8 +3493,8 @@ static int __devinit cciss_init_one(struct pci_dev *pdev,
 	/* command and error info recs zeroed out before
 	   they are used */
 	memset(hba[i]->cmd_pool_bits, 0,
-	       ((hba[i]->nr_cmds + BITS_PER_LONG -
-		 1) / BITS_PER_LONG) * sizeof(unsigned long));
+	       DIV_ROUND_UP(hba[i]->nr_cmds, BITS_PER_LONG)
+			* sizeof(unsigned long));
 	hba[i]->num_luns = 0;
 	hba[i]->highest_lun = -1;
diff --git a/drivers/block/cpqarray.c b/drivers/block/cpqarray.c
index 09c1434..3d96752 100644
--- a/drivers/block/cpqarray.c
+++ b/drivers/block/cpqarray.c
@@ -424,7 +424,7 @@ static int __init cpqarray_register_ctlr( int i, struct pci_dev *pdev)
 		hba[i]->pci_dev, NR_CMDS * sizeof(cmdlist_t),
 		&(hba[i]->cmd_pool_dhandle));
 	hba[i]->cmd_pool_bits = kcalloc(
-		(NR_CMDS+BITS_PER_LONG-1)/BITS_PER_LONG, sizeof(unsigned long),
+		DIV_ROUND_UP(NR_CMDS, BITS_PER_LONG), sizeof(unsigned long),
 		GFP_KERNEL);
 	if (!hba[i]->cmd_pool_bits || !hba[i]->cmd_pool)
diff --git a/drivers/block/floppy.c b/drivers/block/floppy.c
index 395f8ea..9c0b494 100644
--- a/drivers/block/floppy.c
+++ b/drivers/block/floppy.c
@@ -1355,20 +1355,20 @@ static void fdc_specify(void)
 	/* Convert step rate from microseconds to milliseconds and 4 bits */
-	srt = 16 - (DP->srt * scale_dtr / 1000 + NOMINAL_DTR - 1) / NOMINAL_DTR;
+	srt = 16 - DIV_ROUND_UP(DP->srt * scale_dtr / 1000, NOMINAL_DTR);
 	if (slow_floppy) {
 		srt = srt / 4;
 	SUPBOUND(srt, 0xf);
 	INFBOUND(srt, 0);
-	hlt = (DP->hlt * scale_dtr / 2 + NOMINAL_DTR - 1) / NOMINAL_DTR;
+	hlt = DIV_ROUND_UP(DP->hlt * scale_dtr / 2, NOMINAL_DTR);
 	if (hlt < 0x01)
 		hlt = 0x01;
 	else if (hlt > 0x7f)
 		hlt = hlt_max_code;
-	hut = (DP->hut * scale_dtr / 16 + NOMINAL_DTR - 1) / NOMINAL_DTR;
+	hut = DIV_ROUND_UP(DP->hut * scale_dtr / 16, NOMINAL_DTR);
 	if (hut < 0x1)
 		hut = 0x1;
 	else if (hut > 0xf)
@@ -2385,7 +2385,7 @@ static void rw_interrupt(void)
 #ifdef FLOPPY_SANITY_CHECK
 	if (nr_sectors / ssize >
-	    (in_sector_offset + current_count_sectors + ssize - 1) / ssize) {
+	    DIV_ROUND_UP(in_sector_offset + current_count_sectors, ssize)) {
 		DPRINT("long rw: %x instead of %lx\n",
 		       nr_sectors, current_count_sectors);
 		printk("rs=%d s=%d\n", R_SECTOR, SECTOR); |
