drivers/atm/solos-pci.c: exchange pci_iounmaps
Author: Julia Lawall <Julia.Lawall@lip6.fr>
The calls to pci_iounmap are in the wrong order, as compared to the
associated calls to pci_iomap.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e,x;
statement S,S1;
int ret;
e = pci_iomap(x,...)
... when != pci_iounmap(x,e)
if (<+...e...+>) S
... when any
*if (...)
   { ... when != pci_iounmap(x,e)
     return ...; }
... when any
pci_iounmap(x,e);
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/atm/solos-pci.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/atm/solos-pci.c b/drivers/atm/solos-pci.c
index 5d1d076..e8cd652 100644
--- a/drivers/atm/solos-pci.c
+++ b/drivers/atm/solos-pci.c
@@ -1206,9 +1206,9 @@ static int fpga_probe(struct pci_dev *dev, const struct pci_device_id *id)
  out_unmap_both:
 	pci_set_drvdata(dev, NULL);
-	pci_iounmap(dev, card->config_regs);
- out_unmap_config:
 	pci_iounmap(dev, card->buffers);
+ out_unmap_config:
+	pci_iounmap(dev, card->config_regs);
  out_release_regions:
 	pci_release_regions(dev);
  out:
BtrLinux
Privacy Overview
