drivers/atm/firestream.c: Fix unsigned return type
The function has an unsigned return type, but returns a negative constant
to indicate an error condition.  The result of calling the function is
always stored in a variable of type (signed) int, and thus unsigned can be
dropped from the return type.
A sematic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@exists@
identifier f;
constant C;
 unsigned f(...)
*  return -C;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/atm/firestream.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/atm/firestream.c b/drivers/atm/firestream.c
index 8717809..5d86bb8 100644
--- a/drivers/atm/firestream.c
+++ b/drivers/atm/firestream.c
@@ -444,8 +444,8 @@ static inline void fs_kfree_skb (struct sk_buff * skb)
 #define ROUND_NEAREST 3
 /********** make rate (not quite as much fun as Horizon) **********/
-static unsigned int make_rate (unsigned int rate, int r,
-			       u16 * bits, unsigned int * actual)
+static int make_rate(unsigned int rate, int r,
+		      u16 *bits, unsigned int *actual)
 	unsigned char exp = -1; /* hush gcc */
 	unsigned int man = -1;  /* hush gcc */
BtrLinux
Privacy Overview
