drivers/atm/atmtcp.c: add missing atm_dev_put
The earlier call to atm_dev_lookup increases the reference count of dev,
so decrease it on the way out.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression x, E;
constant C;
x = atm_dev_lookup(...);
... when != false x != NULL
    when != true x == NULL
    when != \(E = x\|x = E\)
    when != atm_dev_put(dev);
*return -C;
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/atm/atmtcp.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/drivers/atm/atmtcp.c b/drivers/atm/atmtcp.c
index 2b464b6..0b06250 100644
--- a/drivers/atm/atmtcp.c
+++ b/drivers/atm/atmtcp.c
@@ -392,7 +392,10 @@ static int atmtcp_attach(struct atm_vcc *vcc,int itf)
 			atm_dev_put(dev);
 			return -EMEDIUMTYPE;
-		if (PRIV(dev)->vcc) return -EBUSY;
+		if (PRIV(dev)->vcc) {
+			atm_dev_put(dev);
+			return -EBUSY;
 	else {
 		int error;
BtrLinux
Privacy Overview
