drivers/atm: use time_before, time_before_eq, etc
The functions time_before, time_before_eq, time_after, and time_after_eq
are more robust for comparing jiffies against other values.
A simplified version of the semantic patch making this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ change_compare_np @
expression E;
- jiffies <= E
+ time_before_eq(jiffies,E)
- jiffies >= E
+ time_after_eq(jiffies,E)
- jiffies < E
+ time_before(jiffies,E)
- jiffies > E
+ time_after(jiffies,E)
@ include depends on change_compare_np @
#include
@ no_include depends on !include && change_compare_np @
  #include
+ #include
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: David S. Miller
 drivers/atm/iphase.c | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/atm/iphase.c b/drivers/atm/iphase.c
index 670c093..5c28ca7 100644
--- a/drivers/atm/iphase.c
+++ b/drivers/atm/iphase.c
@@ -60,7 +60,8 @@
 #include <asm/uaccess.h>
 #include <asm/string.h>
 #include <asm/byteorder.h>
-#include <linux/vmalloc.h>
+#include <linux/vmalloc.h>
+#include <linux/jiffies.h>
 #include "iphase.h"
 #include "suni.h"
 #define swap(x) (((x & 0xff) << 8) | ((x & 0xff00) >> 8))
@@ -189,7 +190,7 @@ static u16 get_desc (IADEV *dev, struct ia_vcc *iavcc) {
   int ltimeout;
   ia_hack_tcq (dev);
-  if(((jiffies - timer)>50)||((dev->ffL.tcq_rd==dev->host_tcq_wr))){
+  if((time_after(jiffies,timer+50)) || ((dev->ffL.tcq_rd==dev->host_tcq_wr))) {
      timer = jiffies;
      i=0;
      while (i < dev->num_tx_desc) {
@@ -1225,7 +1226,7 @@ static void rx_intr(struct atm_dev *dev)
         iadev->rx_tmp_jif = jiffies;
         iadev->rxing = 0;
-     else if (((jiffies - iadev->rx_tmp_jif) > 50) &&
+     else if ((time_after(jiffies, iadev->rx_tmp_jif + 50)) &&
                ((iadev->rx_pkt_cnt - iadev->rx_tmp_cnt) == 0)) {
         for (i = 1; i <= iadev->num_rx_desc; i++)
                free_desc(dev, i);
BtrLinux
Privacy Overview
