drivers/atm: Use DIV_ROUND_CLOSEST
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
#include
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/atm/horizon.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/atm/horizon.c b/drivers/atm/horizon.c
index 6b969f8..01ce241 100644
--- a/drivers/atm/horizon.c
+++ b/drivers/atm/horizon.c
@@ -641,7 +641,7 @@ static int make_rate (const hrz_dev * dev, u32 c, rounding r,
 					pre = 1;
 				break;
 			case round_nearest:
-				pre = (br+(c<<div)/2)/(c<<div);
+				pre = DIV_ROUND_CLOSEST(br, c<<div);
 				// but p must be non-zero
 				if (!pre)
 					pre = 1;
@@ -671,7 +671,7 @@ static int make_rate (const hrz_dev * dev, u32 c, rounding r,
 					pre = DIV_ROUND_UP(br, c<<div);
 					break;
 				case round_nearest:
 					break;
 				default: /* round_up */
 					pre = br/(c<<div);
BtrLinux
Privacy Overview
