drivers/atm: Correct redundant test
str has already been tested.  It seems that this test should be on the
recently returned value snr.
A simplified version of the semantic match that finds this problem is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
expression E;
if (x == NULL || ...) { ... when forall
   return ...; }
... when != \(x=E\|x--\|x++\|--x\|++x\|x-=E\|x+=E\|x|=E\|x&=E\|&x\)
*x == NULL
*x != NULL
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/atm/solos-pci.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/atm/solos-pci.c b/drivers/atm/solos-pci.c
index 9359613..307321b 100644
--- a/drivers/atm/solos-pci.c
+++ b/drivers/atm/solos-pci.c
@@ -372,7 +372,7 @@ static int process_status(struct solos_card *card, int port, struct sk_buff *skb
 	snr = next_string(skb);
-	if (!str)
+	if (!snr)
 		return -EIO;
 	attn = next_string(skb);
 	if (!attn)
BtrLinux
Privacy Overview
