drivers/atm: Correct code taking the size of a pointer
sizeof(TstSchedTbl) is just the size of the pointer.  Change it to the size
of the referenced data.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression *x;
expression f;
type T;
*f(...,(T)x,...)
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 drivers/atm/iphase.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/atm/iphase.c b/drivers/atm/iphase.c
index f734b34..25a4c86 100644
--- a/drivers/atm/iphase.c
+++ b/drivers/atm/iphase.c
@@ -557,7 +557,7 @@ static int ia_cbr_setup (IADEV *dev, struct atm_vcc *vcc) {
           memcpy((caddr_t)&cbrVC,(caddr_t)TstSchedTbl,sizeof(cbrVC));
        } /* while */
        // Move this VCI number into this location of the CBR Sched table.
-       memcpy((caddr_t)TstSchedTbl, (caddr_t)&vcIndex,sizeof(TstSchedTbl));
+       memcpy((caddr_t)TstSchedTbl, (caddr_t)&vcIndex, sizeof(*TstSchedTbl));
        dev->CbrRemEntries--;
        toBeAssigned--;
    } /* while */
BtrLinux
Privacy Overview
