drivers/ata/sata_dwc_460ex.c: add missing kfree
Currently, error handling code in this function calls the function
sata_dwc_port_stop, but this function has essentially no effect if hsdevp
has not been stored in ap, which is the case throughout this function.  The
only effect is to print a debugging message including ap->print_id.
The code is rewritten to not call sata_dwc_port_stop, but instead to jump
to a local label that prints the original error message and the print_id
information.  In the case where hsdevp has been already allocated (but not
yet stored in ap), this value is freed as well.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@exists@
local idexpression x;
statement S,S1;
expression E;
identifier fl;
expression *ptr != NULL;
x = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...kfree(x)...+> }
     when any
     when != true x == NULL
x->fl
if (x == NULL) S1
if (...) { ... when != x
               when forall
 return \(0\|<+...x...+>\|ptr\);
* return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Jeff Garzik
 drivers/ata/sata_dwc_460ex.c | 14 ++++++--------
 1 file changed, 6 insertions(+), 8 deletions(-)
diff --git a/drivers/ata/sata_dwc_460ex.c b/drivers/ata/sata_dwc_460ex.c
index 0a9a774..5c42374 100644
--- a/drivers/ata/sata_dwc_460ex.c
+++ b/drivers/ata/sata_dwc_460ex.c
@@ -1329,7 +1329,7 @@ static int sata_dwc_port_start(struct ata_port *ap)
 			dev_err(ap->dev, "%s: dma_alloc_coherent failed\n",
 				 __func__);
 			err = -ENOMEM;
-			goto CLEANUP;
+			goto CLEANUP_ALLOC;
@@ -1349,15 +1349,13 @@ static int sata_dwc_port_start(struct ata_port *ap)
 	/* Clear any error bits before libata starts issuing commands */
 	clear_serror();
 	ap->private_data = hsdevp;
+	dev_dbg(ap->dev, "%s: done\n", __func__);
+	return 0;
+CLEANUP_ALLOC:
+	kfree(hsdevp);
 CLEANUP:
-	if (err) {
-		sata_dwc_port_stop(ap);
-		dev_dbg(ap->dev, "%s: fail\n", __func__);
-	} else {
-		dev_dbg(ap->dev, "%s: done\n", __func__);
+	dev_dbg(ap->dev, "%s: fail. ap->id = %d\n", __func__, ap->print_id);
 	return err;
