drivers/ata/pata_pcmcia.c: adjust suspicious bit operation
Author: Julia Lawall <Julia.Lawall@lip6.fr>
IO_DATA_PATH_WIDTH_8 is 0, so a bit-and with it is always false.  The
value IO_DATA_PATH_WIDTH covers the bits of the IO_DATA_PATH constants, so
first pick those bits and then make the test using !=.
This problem was found using Coccinelle (http://coccinelle.lip6.fr/).
Signed-off-by: Julia Lawall
Signed-off-by: Jeff Garzik
 drivers/ata/pata_pcmcia.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/ata/pata_pcmcia.c b/drivers/ata/pata_pcmcia.c
index a808ba0..958238d 100644
--- a/drivers/ata/pata_pcmcia.c
+++ b/drivers/ata/pata_pcmcia.c
@@ -170,7 +170,8 @@ static int pcmcia_check_one_config(struct pcmcia_device *pdev, void *priv_data)
 	int *is_kme = priv_data;
-	if (!(pdev->resource[0]->flags & IO_DATA_PATH_WIDTH_8)) {
+	if ((pdev->resource[0]->flags & IO_DATA_PATH_WIDTH)
+	    != IO_DATA_PATH_WIDTH_8) {
 		pdev->resource[0]->flags &= ~IO_DATA_PATH_WIDTH;
 		pdev->resource[0]->flags |= IO_DATA_PATH_WIDTH_AUTO;
BtrLinux
Privacy Overview
