drivers/amdgpu: Use canonical form in branch predicates
Author: Edward O'Callaghan <funfunctor@folklore1984.net>
Found-by: Coccinelle
Signed-off-by: Edward O'Callaghan
Reviewed-by: Tom St Denis
Reviewed-by: Christian König
Signed-off-by: Alex Deucher
 drivers/gpu/drm/amd/amdgpu/amdgpu_bios.c | 14 +++++++-------
 drivers/gpu/drm/amd/amdgpu/ci_dpm.c      |  2 +-
 drivers/gpu/drm/amd/amdgpu/cik.c         |  2 +-
 drivers/gpu/drm/amd/amdgpu/cik_sdma.c    |  2 +-
 drivers/gpu/drm/amd/amdgpu/sdma_v2_4.c   |  2 +-
 drivers/gpu/drm/amd/amdgpu/sdma_v3_0.c   |  2 +-
 6 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/gpu/drm/amd/amdgpu/amdgpu_bios.c b/drivers/gpu/drm/amd/amdgpu/amdgpu_bios.c
index 99ca75b..2b6afe1 100644
--- a/drivers/gpu/drm/amd/amdgpu/amdgpu_bios.c
+++ b/drivers/gpu/drm/amd/amdgpu/amdgpu_bios.c
@@ -352,22 +352,22 @@ bool amdgpu_get_bios(struct amdgpu_device *adev)
 	uint16_t tmp, bios_header_start;
 	r = amdgpu_atrm_get_bios(adev);
-	if (r == false)
+	if (!r)
 		r = amdgpu_acpi_vfct_bios(adev);
-	if (r == false)
+	if (!r)
 		r = igp_read_bios_from_vram(adev);
-	if (r == false)
+	if (!r)
 		r = amdgpu_read_bios(adev);
-	if (r == false) {
+	if (!r) {
 		r = amdgpu_read_bios_from_rom(adev);
-	if (r == false) {
+	if (!r) {
 		r = amdgpu_read_disabled_bios(adev);
-	if (r == false) {
+	if (!r) {
 		r = amdgpu_read_platform_bios(adev);
-	if (r == false || adev->bios == NULL) {
+	if (!r || adev->bios == NULL) {
 		DRM_ERROR("Unable to locate a BIOS ROM\n");
 		adev->bios = NULL;
 		return false;
diff --git a/drivers/gpu/drm/amd/amdgpu/ci_dpm.c b/drivers/gpu/drm/amd/amdgpu/ci_dpm.c
index 573bc97..42a59fc 100644
--- a/drivers/gpu/drm/amd/amdgpu/ci_dpm.c
+++ b/drivers/gpu/drm/amd/amdgpu/ci_dpm.c
@@ -3034,7 +3034,7 @@ static int ci_populate_single_memory_level(struct amdgpu_device *adev,
 	if (pi->mclk_stutter_mode_threshold &&
 	    (memory_clock <= pi->mclk_stutter_mode_threshold) &&
-	    (pi->uvd_enabled == false) &&
+	    (!pi->uvd_enabled) &&
 	    (RREG32(mmDPG_PIPE_STUTTER_CONTROL) & DPG_PIPE_STUTTER_CONTROL__STUTTER_ENABLE_MASK) &&
 	    (adev->pm.dpm.new_active_crtc_count <= 2))
 		memory_level->StutterEnable = true;
diff --git a/drivers/gpu/drm/amd/amdgpu/cik.c b/drivers/gpu/drm/amd/amdgpu/cik.c
index a7de4d1..4efc901 100644
--- a/drivers/gpu/drm/amd/amdgpu/cik.c
+++ b/drivers/gpu/drm/amd/amdgpu/cik.c
@@ -879,7 +879,7 @@ static void cik_vga_set_state(struct amdgpu_device *adev, bool state)
 	uint32_t tmp;
 	tmp = RREG32(mmCONFIG_CNTL);
-	if (state == false)
+	if (!state)
 		tmp |= CONFIG_CNTL__VGA_DIS_MASK;
 	else
 		tmp &= ~CONFIG_CNTL__VGA_DIS_MASK;
diff --git a/drivers/gpu/drm/amd/amdgpu/cik_sdma.c b/drivers/gpu/drm/amd/amdgpu/cik_sdma.c
index 6507a7e..c1eedc4 100644
--- a/drivers/gpu/drm/amd/amdgpu/cik_sdma.c
+++ b/drivers/gpu/drm/amd/amdgpu/cik_sdma.c
@@ -354,7 +354,7 @@ static void cik_sdma_enable(struct amdgpu_device *adev, bool enable)
 	u32 me_cntl;
 	int i;
-	if (enable == false) {
+	if (!enable) {
 		cik_sdma_gfx_stop(adev);
 		cik_sdma_rlc_stop(adev);
diff --git a/drivers/gpu/drm/amd/amdgpu/sdma_v2_4.c b/drivers/gpu/drm/amd/amdgpu/sdma_v2_4.c
index 0111d15..9d43c6c 100644
--- a/drivers/gpu/drm/amd/amdgpu/sdma_v2_4.c
+++ b/drivers/gpu/drm/amd/amdgpu/sdma_v2_4.c
@@ -393,7 +393,7 @@ static void sdma_v2_4_enable(struct amdgpu_device *adev, bool enable)
 	u32 f32_cntl;
 	int i;
+	if (!enable) {
 		sdma_v2_4_gfx_stop(adev);
 		sdma_v2_4_rlc_stop(adev);
diff --git a/drivers/gpu/drm/amd/amdgpu/sdma_v3_0.c b/drivers/gpu/drm/amd/amdgpu/sdma_v3_0.c
index 2b8ce58..4debd0d 100644
--- a/drivers/gpu/drm/amd/amdgpu/sdma_v3_0.c
+++ b/drivers/gpu/drm/amd/amdgpu/sdma_v3_0.c
@@ -604,7 +604,7 @@ static void sdma_v3_0_enable(struct amdgpu_device *adev, bool enable)
 	u32 f32_cntl;
 	int i;
+	if (!enable) {
 		sdma_v3_0_gfx_stop(adev);
 		sdma_v3_0_rlc_stop(adev);
BtrLinux
Privacy Overview
