drivers: video: fbdev: atmel_lcdfb.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Acked-by: Nicolas Ferre
Signed-off-by: Tomi Valkeinen
 drivers/video/fbdev/atmel_lcdfb.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/drivers/video/fbdev/atmel_lcdfb.c b/drivers/video/fbdev/atmel_lcdfb.c
index 92640d4..1d8bdb9 100644
--- a/drivers/video/fbdev/atmel_lcdfb.c
+++ b/drivers/video/fbdev/atmel_lcdfb.c
@@ -1102,12 +1102,14 @@ static int atmel_lcdfb_of_init(struct atmel_lcdfb_info *sinfo)
 	timings = of_get_display_timings(display_np);
 	if (!timings) {
 		dev_err(dev, "failed to get display timings\n");
+		ret = -EINVAL;
 		goto put_display_node;
 	timings_np = of_find_node_by_name(display_np, "display-timings");
 	if (!timings_np) {
 		dev_err(dev, "failed to find display-timings node\n");
+		ret = -ENODEV;
BtrLinux
Privacy Overview
