drivers: pinctrl: vt8500: use devm_ioremap_resource()
Author: Laurent Navet <laurent.navet@gmail.com>
Replace a call to deprecated devm_request_and_ioremap by devm_ioremap_resource.
Found with coccicheck and this semantic patch:
scripts/coccinelle/api/devm_ioremap_resource.cocci
Signed-off-by: Laurent Navet
Acked-by: Tony Prisk
Signed-off-by: Linus Walleij
drivers/pinctrl/vt8500/pinctrl-wmt.c | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/pinctrl/vt8500/pinctrl-wmt.c b/drivers/pinctrl/vt8500/pinctrl-wmt.c
index 70d986e..fb30edf3 100644
--- a/drivers/pinctrl/vt8500/pinctrl-wmt.c
+++ b/drivers/pinctrl/vt8500/pinctrl-wmt.c
@@ -569,10 +569,10 @@ int wmt_pinctrl_probe(struct platform_device *pdev,
struct resource *res;
res = platform_get_resource(pdev, IORESOURCE_MEM, 0);
- data->base = devm_request_and_ioremap(&pdev->dev, res);
- if (!data->base) {
+ data->base = devm_ioremap_resource(&pdev->dev, res);
+ if (IS_ERR(data->base)) {
dev_err(&pdev->dev, "failed to map memory resource\n");
- return -EBUSY;
+ return PTR_ERR(data->base);
wmt_desc.pins = data->pins; |
- return -EBUSY;
