drivers: Final irq namespace conversion
Author: Thomas Gleixner <tglx@linutronix.de>
Scripted with coccinelle.
Signed-off-by: Thomas Gleixner
 drivers/ata/pata_ixp4xx_cf.c                             |  2 +-
 drivers/ata/pata_rb532_cf.c                              |  4 ++--
 drivers/hwmon/gpio-fan.c                                 |  2 +-
 drivers/input/keyboard/lm8323.c                          |  4 ++--
 drivers/input/serio/ams_delta_serio.c                    |  2 +-
 drivers/input/touchscreen/mainstone-wm97xx.c             |  2 +-
 drivers/input/touchscreen/zylonite-wm97xx.c              |  2 +-
 drivers/misc/sgi-gru/grufile.c                           |  2 +-
 drivers/mmc/host/sdhci-spear.c                           |  2 +-
 drivers/net/dm9000.c                                     |  8 ++++----
 drivers/net/wireless/p54/p54spi.c                        |  3 +--
 drivers/net/wireless/wl1251/sdio.c                       |  2 +-
 drivers/net/wireless/wl1251/spi.c                        |  2 +-
 drivers/pci/dmar.c                                       | 12 ++++++------
 drivers/pci/htirq.c                                      | 16 ++++++++--------
 drivers/pci/intel-iommu.c                                |  2 +-
 drivers/pci/intr_remapping.c                             |  2 +-
 drivers/pci/msi.c                                        | 10 +++++-----
 drivers/pcmcia/bfin_cf_pcmcia.c                          |  2 +-
 drivers/pcmcia/db1xxx_ss.c                               |  2 +-
 drivers/pcmcia/sa1100_nanoengine.c                       |  2 +-
 drivers/pcmcia/soc_common.c                              | 14 +++++++-------
 drivers/pcmcia/xxs1500_ss.c                              |  2 +-
 drivers/platform/x86/intel_pmic_gpio.c                   |  8 +++++---
 drivers/power/z2_battery.c                               |  4 ++--
 drivers/rtc/rtc-sh.c                                     |  6 +++---
 drivers/staging/brcm80211/brcmfmac/bcmsdh_linux.c        |  4 ++--
 .../astoria/arch/arm/mach-omap2/cyashalomap_kernel.c     |  2 +-
 drivers/tty/hvc/hvc_xen.c                                |  2 +-
 drivers/tty/serial/msm_serial_hs.c                       |  4 ++--
 drivers/usb/host/oxu210hp-hcd.c                          |  2 +-
 drivers/usb/musb/tusb6010.c                              |  2 +-
 drivers/w1/masters/ds1wm.c                               |  4 ++--
 33 files changed, 70 insertions(+), 69 deletions(-)
diff --git a/drivers/ata/pata_ixp4xx_cf.c b/drivers/ata/pata_ixp4xx_cf.c
index 5253b27..f6b3f99 100644
--- a/drivers/ata/pata_ixp4xx_cf.c
+++ b/drivers/ata/pata_ixp4xx_cf.c
@@ -167,7 +167,7 @@ static __devinit int ixp4xx_pata_probe(struct platform_device *pdev)
 	irq = platform_get_irq(pdev, 0);
 	if (irq)
-		set_irq_type(irq, IRQ_TYPE_EDGE_RISING);
+		irq_set_irq_type(irq, IRQ_TYPE_EDGE_RISING);
 	/* Setup expansion bus chip selects */
 	*data->cs0_cfg = data->cs0_bits;
diff --git a/drivers/ata/pata_rb532_cf.c b/drivers/ata/pata_rb532_cf.c
index baeaf938..1b9d10d 100644
--- a/drivers/ata/pata_rb532_cf.c
+++ b/drivers/ata/pata_rb532_cf.c
@@ -60,10 +60,10 @@ static irqreturn_t rb532_pata_irq_handler(int irq, void *dev_instance)
 	struct rb532_cf_info *info = ah->private_data;
 	if (gpio_get_value(info->gpio_line)) {
-		set_irq_type(info->irq, IRQ_TYPE_LEVEL_LOW);
+		irq_set_irq_type(info->irq, IRQ_TYPE_LEVEL_LOW);
 		ata_sff_interrupt(info->irq, dev_instance);
 	} else {
-		set_irq_type(info->irq, IRQ_TYPE_LEVEL_HIGH);
+		irq_set_irq_type(info->irq, IRQ_TYPE_LEVEL_HIGH);
 	return IRQ_HANDLED;
diff --git a/drivers/hwmon/gpio-fan.c b/drivers/hwmon/gpio-fan.c
index f141a1d..89aa9fb 100644
--- a/drivers/hwmon/gpio-fan.c
+++ b/drivers/hwmon/gpio-fan.c
@@ -116,7 +116,7 @@ static int fan_alarm_init(struct gpio_fan_data *fan_data,
 		return 0;
 	INIT_WORK(&fan_data->alarm_work, fan_alarm_notify);
-	set_irq_type(alarm_irq, IRQ_TYPE_EDGE_BOTH);
+	irq_set_irq_type(alarm_irq, IRQ_TYPE_EDGE_BOTH);
 	err = request_irq(alarm_irq, fan_alarm_irq_handler, IRQF_SHARED,
 			  "GPIO fan alarm", fan_data);
 	if (err)
diff --git a/drivers/input/keyboard/lm8323.c b/drivers/input/keyboard/lm8323.c
index b732870..71f744a8 100644
--- a/drivers/input/keyboard/lm8323.c
+++ b/drivers/input/keyboard/lm8323.c
@@ -809,7 +809,7 @@ static int lm8323_suspend(struct device *dev)
 	struct lm8323_chip *lm = i2c_get_clientdata(client);
 	int i;
-	set_irq_wake(client->irq, 0);
+	irq_set_irq_wake(client->irq, 0);
 	disable_irq(client->irq);
 	mutex_lock(&lm->lock);
@@ -838,7 +838,7 @@ static int lm8323_resume(struct device *dev)
 			led_classdev_resume(&lm->pwm[i].cdev);
 	enable_irq(client->irq);
-	set_irq_wake(client->irq, 1);
+	irq_set_irq_wake(client->irq, 1);
 	return 0;
diff --git a/drivers/input/serio/ams_delta_serio.c b/drivers/input/serio/ams_delta_serio.c
index ebe9553..4b2a42f 100644
--- a/drivers/input/serio/ams_delta_serio.c
+++ b/drivers/input/serio/ams_delta_serio.c
@@ -149,7 +149,7 @@ static int __init ams_delta_serio_init(void)
 	 * at FIQ level, switch back from edge to simple interrupt handler
 	 * to avoid bad interaction.
-	set_irq_handler(gpio_to_irq(AMS_DELTA_GPIO_PIN_KEYBRD_CLK),
+	irq_set_handler(gpio_to_irq(AMS_DELTA_GPIO_PIN_KEYBRD_CLK),
 			handle_simple_irq);
 	serio_register_port(ams_delta_serio);
diff --git a/drivers/input/touchscreen/mainstone-wm97xx.c b/drivers/input/touchscreen/mainstone-wm97xx.c
index b6b8b1c..3242e70 100644
--- a/drivers/input/touchscreen/mainstone-wm97xx.c
+++ b/drivers/input/touchscreen/mainstone-wm97xx.c
@@ -219,7 +219,7 @@ static int wm97xx_acc_startup(struct wm97xx *wm)
 		wm->pen_irq = gpio_to_irq(irq);
-		set_irq_type(wm->pen_irq, IRQ_TYPE_EDGE_BOTH);
+		irq_set_irq_type(wm->pen_irq, IRQ_TYPE_EDGE_BOTH);
 	} else /* pen irq not supported */
 		pen_int = 0;
diff --git a/drivers/input/touchscreen/zylonite-wm97xx.c b/drivers/input/touchscreen/zylonite-wm97xx.c
index 0488498..5b0f15e 100644
--- a/drivers/input/touchscreen/zylonite-wm97xx.c
+++ b/drivers/input/touchscreen/zylonite-wm97xx.c
@@ -193,7 +193,7 @@ static int zylonite_wm97xx_probe(struct platform_device *pdev)
 		gpio_touch_irq = mfp_to_gpio(MFP_PIN_GPIO26);
 	wm->pen_irq = IRQ_GPIO(gpio_touch_irq);
-	set_irq_type(IRQ_GPIO(gpio_touch_irq), IRQ_TYPE_EDGE_BOTH);
+	irq_set_irq_type(IRQ_GPIO(gpio_touch_irq), IRQ_TYPE_EDGE_BOTH);
 	wm97xx_config_gpio(wm, WM97XX_GPIO_13, WM97XX_GPIO_IN,
 			   WM97XX_GPIO_POL_HIGH,
diff --git a/drivers/misc/sgi-gru/grufile.c b/drivers/misc/sgi-gru/grufile.c
index 28852df..20e4e93 100644
--- a/drivers/misc/sgi-gru/grufile.c
+++ b/drivers/misc/sgi-gru/grufile.c
@@ -373,7 +373,7 @@ static int gru_chiplet_setup_tlb_irq(int chiplet, char *irq_name,
 	if (gru_irq_count[chiplet] == 0) {
 		gru_chip[chiplet].name = irq_name;
-		ret = set_irq_chip(irq, &gru_chip[chiplet]);
+		ret = irq_set_chip(irq, &gru_chip[chiplet]);
 		if (ret) {
 			printk(KERN_ERR "%s: set_irq_chip failed, errno=%d\n",
 			       GRU_DRIVER_ID_STR, -ret);
diff --git a/drivers/mmc/host/sdhci-spear.c b/drivers/mmc/host/sdhci-spear.c
index d70c54c..60a4c97 100644
--- a/drivers/mmc/host/sdhci-spear.c
+++ b/drivers/mmc/host/sdhci-spear.c
@@ -50,7 +50,7 @@ static irqreturn_t sdhci_gpio_irq(int irq, void *dev_id)
 	/* val == 1 -> card removed, val == 0 -> card inserted */
 	/* if card removed - set irq for low level, else vice versa */
 	gpio_irq_type = val ? IRQF_TRIGGER_LOW : IRQF_TRIGGER_HIGH;
-	set_irq_type(irq, gpio_irq_type);
+	irq_set_irq_type(irq, gpio_irq_type);
 	if (sdhci->data->card_power_gpio >= 0) {
 		if (!sdhci->data->power_always_enb) {
diff --git a/drivers/net/dm9000.c b/drivers/net/dm9000.c
index 3177081..b7af5ba 100644
--- a/drivers/net/dm9000.c
+++ b/drivers/net/dm9000.c
@@ -621,9 +621,9 @@ static int dm9000_set_wol(struct net_device *dev, struct ethtool_wolinfo *w)
 		/* change in wol state, update IRQ state */
 		if (!dm->wake_state)
-			set_irq_wake(dm->irq_wake, 1);
+			irq_set_irq_wake(dm->irq_wake, 1);
 		else if (dm->wake_state & !opts)
-			set_irq_wake(dm->irq_wake, 0);
+			irq_set_irq_wake(dm->irq_wake, 0);
 	dm->wake_state = opts;
@@ -1424,13 +1424,13 @@ dm9000_probe(struct platform_device *pdev)
 		} else {
 			/* test to see if irq is really wakeup capable */
-			ret = set_irq_wake(db->irq_wake, 1);
+			ret = irq_set_irq_wake(db->irq_wake, 1);
 			if (ret) {
 				dev_err(db->dev, "irq %d cannot set wakeup (%d)\n",
 					db->irq_wake, ret);
 				ret = 0;
 			} else {
-				set_irq_wake(db->irq_wake, 0);
+				irq_set_irq_wake(db->irq_wake, 0);
 				db->wake_supported = 1;
diff --git a/drivers/net/wireless/p54/p54spi.c b/drivers/net/wireless/p54/p54spi.c
index 18d24b7..7ecc0bd 100644
--- a/drivers/net/wireless/p54/p54spi.c
+++ b/drivers/net/wireless/p54/p54spi.c
@@ -649,8 +649,7 @@ static int __devinit p54spi_probe(struct spi_device *spi)
 		goto err_free_common;
-	set_irq_type(gpio_to_irq(p54spi_gpio_irq),
-		     IRQ_TYPE_EDGE_RISING);
+	irq_set_irq_type(gpio_to_irq(p54spi_gpio_irq), IRQ_TYPE_EDGE_RISING);
 	disable_irq(gpio_to_irq(p54spi_gpio_irq));
diff --git a/drivers/net/wireless/wl1251/sdio.c b/drivers/net/wireless/wl1251/sdio.c
index d550b5e..f51a024 100644
--- a/drivers/net/wireless/wl1251/sdio.c
+++ b/drivers/net/wireless/wl1251/sdio.c
@@ -265,7 +265,7 @@ static int wl1251_sdio_probe(struct sdio_func *func,
 			goto disable;
-		set_irq_type(wl->irq, IRQ_TYPE_EDGE_RISING);
+		irq_set_irq_type(wl->irq, IRQ_TYPE_EDGE_RISING);
 		disable_irq(wl->irq);
 		wl1251_sdio_ops.enable_irq = wl1251_enable_line_irq;
diff --git a/drivers/net/wireless/wl1251/spi.c b/drivers/net/wireless/wl1251/spi.c
index ac872b3..af6448c 100644
--- a/drivers/net/wireless/wl1251/spi.c
+++ b/drivers/net/wireless/wl1251/spi.c
@@ -286,7 +286,7 @@ static int __devinit wl1251_spi_probe(struct spi_device *spi)
 		goto out_free;
diff --git a/drivers/pci/dmar.c b/drivers/pci/dmar.c
index 09933eb..12e02bf 100644
--- a/drivers/pci/dmar.c
+++ b/drivers/pci/dmar.c
@@ -1226,7 +1226,7 @@ const char *dmar_get_fault_reason(u8 fault_reason, int *fault_type)
 void dmar_msi_unmask(struct irq_data *data)
-	struct intel_iommu *iommu = irq_data_get_irq_data(data);
+	struct intel_iommu *iommu = irq_data_get_irq_handler_data(data);
 	unsigned long flag;
 	/* unmask it */
@@ -1240,7 +1240,7 @@ void dmar_msi_unmask(struct irq_data *data)
 void dmar_msi_mask(struct irq_data *data)
 	unsigned long flag;
 	/* mask it */
 	spin_lock_irqsave(&iommu->register_lock, flag);
@@ -1252,7 +1252,7 @@ void dmar_msi_mask(struct irq_data *data)
 void dmar_msi_write(int irq, struct msi_msg *msg)
-	struct intel_iommu *iommu = get_irq_data(irq);
+	struct intel_iommu *iommu = irq_get_handler_data(irq);
 	unsigned long flag;
@@ -1264,7 +1264,7 @@ void dmar_msi_write(int irq, struct msi_msg *msg)
 void dmar_msi_read(int irq, struct msi_msg *msg)
 	unsigned long flag;
@@ -1382,12 +1382,12 @@ int dmar_set_interrupt(struct intel_iommu *iommu)
 		return -EINVAL;
-	set_irq_data(irq, iommu);
+	irq_set_handler_data(irq, iommu);
 	iommu->irq = irq;
 	ret = arch_setup_dmar_msi(irq);
 	if (ret) {
-		set_irq_data(irq, NULL);
+		irq_set_handler_data(irq, NULL);
 		iommu->irq = 0;
 		destroy_irq(irq);
 		return ret;
diff --git a/drivers/pci/htirq.c b/drivers/pci/htirq.c
index 834842a..db057b6 100644
--- a/drivers/pci/htirq.c
+++ b/drivers/pci/htirq.c
@@ -34,7 +34,7 @@ struct ht_irq_cfg {
 void write_ht_irq_msg(unsigned int irq, struct ht_irq_msg *msg)
-	struct ht_irq_cfg *cfg = get_irq_data(irq);
+	struct ht_irq_cfg *cfg = irq_get_handler_data(irq);
 	unsigned long flags;
 	spin_lock_irqsave(&ht_irq_lock, flags);
 	if (cfg->msg.address_lo != msg->address_lo) {
@@ -53,13 +53,13 @@ void write_ht_irq_msg(unsigned int irq, struct ht_irq_msg *msg)
 void fetch_ht_irq_msg(unsigned int irq, struct ht_irq_msg *msg)
 	*msg = cfg->msg;
 void mask_ht_irq(struct irq_data *data)
-	struct ht_irq_cfg *cfg = irq_data_get_irq_data(data);
+	struct ht_irq_cfg *cfg = irq_data_get_irq_handler_data(data);
 	struct ht_irq_msg msg = cfg->msg;
 	msg.address_lo |= 1;
@@ -68,7 +68,7 @@ void mask_ht_irq(struct irq_data *data)
 void unmask_ht_irq(struct irq_data *data)
 	msg.address_lo &= ~1;
@@ -126,7 +126,7 @@ int __ht_create_irq(struct pci_dev *dev, int idx, ht_irq_update_t *update)
 		kfree(cfg);
 		return -EBUSY;
-	set_irq_data(irq, cfg);
+	irq_set_handler_data(irq, cfg);
 	if (arch_setup_ht_irq(irq, dev) < 0) {
 		ht_destroy_irq(irq);
@@ -162,9 +162,9 @@ void ht_destroy_irq(unsigned int irq)
 	struct ht_irq_cfg *cfg;
-	cfg = get_irq_data(irq);
-	set_irq_chip(irq, NULL);
+	cfg = irq_get_handler_data(irq);
+	irq_set_chip(irq, NULL);
 	destroy_irq(irq);
 	kfree(cfg);
diff --git a/drivers/pci/intel-iommu.c b/drivers/pci/intel-iommu.c
index a4115f1..7da3bef 100644
--- a/drivers/pci/intel-iommu.c
+++ b/drivers/pci/intel-iommu.c
@@ -1206,7 +1206,7 @@ void free_dmar_iommu(struct intel_iommu *iommu)
 		iommu_disable_translation(iommu);
 	if (iommu->irq) {
-		set_irq_data(iommu->irq, NULL);
+		irq_set_handler_data(iommu->irq, NULL);
 		/* This will mask the irq */
 		free_irq(iommu->irq, iommu);
 		destroy_irq(iommu->irq);
diff --git a/drivers/pci/intr_remapping.c b/drivers/pci/intr_remapping.c
index ec87cd6..a22557b 100644
--- a/drivers/pci/intr_remapping.c
+++ b/drivers/pci/intr_remapping.c
@@ -50,7 +50,7 @@ static DEFINE_SPINLOCK(irq_2_ir_lock);
 static struct irq_2_iommu *irq_2_iommu(unsigned int irq)
-	struct irq_cfg *cfg = get_irq_chip_data(irq);
+	struct irq_cfg *cfg = irq_get_chip_data(irq);
 	return cfg ? &cfg->irq_2_iommu : NULL;
diff --git a/drivers/pci/msi.c b/drivers/pci/msi.c
index 44b0aee..2f10328 100644
--- a/drivers/pci/msi.c
+++ b/drivers/pci/msi.c
@@ -236,7 +236,7 @@ void __read_msi_msg(struct msi_desc *entry, struct msi_msg *msg)
 void read_msi_msg(unsigned int irq, struct msi_msg *msg)
-	struct msi_desc *entry = get_irq_msi(irq);
+	struct msi_desc *entry = irq_get_msi_desc(irq);
 	__read_msi_msg(entry, msg);
@@ -253,7 +253,7 @@ void __get_cached_msi_msg(struct msi_desc *entry, struct msi_msg *msg)
 void get_cached_msi_msg(unsigned int irq, struct msi_msg *msg)
 	__get_cached_msi_msg(entry, msg);
@@ -297,7 +297,7 @@ void __write_msi_msg(struct msi_desc *entry, struct msi_msg *msg)
 void write_msi_msg(unsigned int irq, struct msi_msg *msg)
 	__write_msi_msg(entry, msg);
@@ -354,7 +354,7 @@ static void __pci_restore_msi_state(struct pci_dev *dev)
 	if (!dev->msi_enabled)
 		return;
-	entry = get_irq_msi(dev->irq);
+	entry = irq_get_msi_desc(dev->irq);
 	pos = entry->msi_attrib.pos;
 	pci_intx_for_msi(dev, 0);
@@ -519,7 +519,7 @@ static void msix_program_entries(struct pci_dev *dev,
 						PCI_MSIX_ENTRY_VECTOR_CTRL;
 		entries[i].vector = entry->irq;
-		set_irq_msi(entry->irq, entry);
+		irq_set_msi_desc(entry->irq, entry);
 		entry->masked = readl(entry->mask_base + offset);
 		msix_mask_irq(entry, 1);
 		i++;
diff --git a/drivers/pcmcia/bfin_cf_pcmcia.c b/drivers/pcmcia/bfin_cf_pcmcia.c
index eae9cbe..4922139 100644
--- a/drivers/pcmcia/bfin_cf_pcmcia.c
+++ b/drivers/pcmcia/bfin_cf_pcmcia.c
@@ -235,7 +235,7 @@ static int __devinit bfin_cf_probe(struct platform_device *pdev)
 	cf->irq = irq;
 	cf->socket.pci_irq = irq;
-	set_irq_type(irq, IRQF_TRIGGER_LOW);
+	irq_set_irq_type(irq, IRQF_TRIGGER_LOW);
 	io_mem = platform_get_resource(pdev, IORESOURCE_MEM, 0);
 	attr_mem = platform_get_resource(pdev, IORESOURCE_MEM, 1);
diff --git a/drivers/pcmcia/db1xxx_ss.c b/drivers/pcmcia/db1xxx_ss.c
index 27575e63..01757f1 100644
--- a/drivers/pcmcia/db1xxx_ss.c
+++ b/drivers/pcmcia/db1xxx_ss.c
@@ -181,7 +181,7 @@ static int db1x_pcmcia_setup_irqs(struct db1x_pcmcia_sock *sock)
 		/* all other (older) Db1x00 boards use a GPIO to show
 		 * card detection status:  use both-edge triggers.
-		set_irq_type(sock->insert_irq, IRQ_TYPE_EDGE_BOTH);
+		irq_set_irq_type(sock->insert_irq, IRQ_TYPE_EDGE_BOTH);
 		ret = request_irq(sock->insert_irq, db1000_pcmcia_cdirq,
 				  0, "pcmcia_carddetect", sock);
diff --git a/drivers/pcmcia/sa1100_nanoengine.c b/drivers/pcmcia/sa1100_nanoengine.c
index 3d2652e..93b9c9b 100644
--- a/drivers/pcmcia/sa1100_nanoengine.c
+++ b/drivers/pcmcia/sa1100_nanoengine.c
@@ -86,7 +86,7 @@ static int nanoengine_pcmcia_hw_init(struct soc_pcmcia_socket *skt)
 	GPDR &= ~nano_skts[i].input_pins;
 	GPDR |= nano_skts[i].output_pins;
 	GPCR = nano_skts[i].clear_outputs;
-	set_irq_type(nano_skts[i].transition_pins, IRQ_TYPE_EDGE_BOTH);
+	irq_set_irq_type(nano_skts[i].transition_pins, IRQ_TYPE_EDGE_BOTH);
 	skt->socket.pci_irq = nano_skts[i].pci_irq;
 	return soc_pcmcia_request_irqs(skt,
diff --git a/drivers/pcmcia/soc_common.c b/drivers/pcmcia/soc_common.c
index 5a9a392..768f957 100644
--- a/drivers/pcmcia/soc_common.c
+++ b/drivers/pcmcia/soc_common.c
@@ -155,11 +155,11 @@ static int soc_common_pcmcia_config_skt(
 		if (skt->irq_state != 1 && state->io_irq) {
 			skt->irq_state = 1;
-			set_irq_type(skt->socket.pci_irq,
-				IRQ_TYPE_EDGE_FALLING);
+			irq_set_irq_type(skt->socket.pci_irq,
+					 IRQ_TYPE_EDGE_FALLING);
 		} else if (skt->irq_state == 1 && state->io_irq == 0) {
 			skt->irq_state = 0;
-			set_irq_type(skt->socket.pci_irq, IRQ_TYPE_NONE);
+			irq_set_irq_type(skt->socket.pci_irq, IRQ_TYPE_NONE);
 		skt->cs_state = *state;
@@ -537,7 +537,7 @@ int soc_pcmcia_request_irqs(struct soc_pcmcia_socket *skt,
 				  IRQF_DISABLED, irqs[i].str, skt);
 		if (res)
 			break;
-		set_irq_type(irqs[i].irq, IRQ_TYPE_NONE);
+		irq_set_irq_type(irqs[i].irq, IRQ_TYPE_NONE);
 	if (res) {
@@ -570,7 +570,7 @@ void soc_pcmcia_disable_irqs(struct soc_pcmcia_socket *skt,
 	for (i = 0; i < nr; i++)
 		if (irqs[i].sock == skt->nr)
 EXPORT_SYMBOL(soc_pcmcia_disable_irqs);
@@ -581,8 +581,8 @@ void soc_pcmcia_enable_irqs(struct soc_pcmcia_socket *skt,
 		if (irqs[i].sock == skt->nr) {
-			set_irq_type(irqs[i].irq, IRQ_TYPE_EDGE_RISING);
-			set_irq_type(irqs[i].irq, IRQ_TYPE_EDGE_BOTH);
+			irq_set_irq_type(irqs[i].irq, IRQ_TYPE_EDGE_RISING);
+			irq_set_irq_type(irqs[i].irq, IRQ_TYPE_EDGE_BOTH);
 EXPORT_SYMBOL(soc_pcmcia_enable_irqs);
diff --git a/drivers/pcmcia/xxs1500_ss.c b/drivers/pcmcia/xxs1500_ss.c
index 3b67a1b..379f421 100644
--- a/drivers/pcmcia/xxs1500_ss.c
+++ b/drivers/pcmcia/xxs1500_ss.c
@@ -274,7 +274,7 @@ static int __devinit xxs1500_pcmcia_probe(struct platform_device *pdev)
 	 * edge detector.
 	irq = gpio_to_irq(GPIO_CDA);
-	set_irq_type(irq, IRQ_TYPE_EDGE_BOTH);
+	irq_set_irq_type(irq, IRQ_TYPE_EDGE_BOTH);
 	ret = request_irq(irq, cdirq, 0, "pcmcia_carddetect", sock);
 	if (ret) {
 		dev_err(&pdev->dev, "cannot setup cd irq\n");
diff --git a/drivers/platform/x86/intel_pmic_gpio.c b/drivers/platform/x86/intel_pmic_gpio.c
index 61433d4..d653104 100644
--- a/drivers/platform/x86/intel_pmic_gpio.c
+++ b/drivers/platform/x86/intel_pmic_gpio.c
@@ -257,9 +257,11 @@ static int __devinit platform_pmic_gpio_probe(struct platform_device *pdev)
 	for (i = 0; i < 8; i++) {
-		set_irq_chip_and_handler_name(i + pg->irq_base, &pmic_irqchip,
-					handle_simple_irq, "demux");
-		set_irq_chip_data(i + pg->irq_base, pg);
+		irq_set_chip_and_handler_name(i + pg->irq_base,
+					      &pmic_irqchip,
+					      handle_simple_irq,
+					      "demux");
+		irq_set_chip_data(i + pg->irq_base, pg);
 	return 0;
 err:
diff --git a/drivers/power/z2_battery.c b/drivers/power/z2_battery.c
index 2a9ab89..e5ced3a 100644
--- a/drivers/power/z2_battery.c
+++ b/drivers/power/z2_battery.c
@@ -215,8 +215,8 @@ static int __devinit z2_batt_probe(struct i2c_client *client,
 		if (ret)
 			goto err2;
-		set_irq_type(gpio_to_irq(info->charge_gpio),
-				IRQ_TYPE_EDGE_BOTH);
+		irq_set_irq_type(gpio_to_irq(info->charge_gpio),
+				 IRQ_TYPE_EDGE_BOTH);
 		ret = request_irq(gpio_to_irq(info->charge_gpio),
 				z2_charge_switch_irq, IRQF_DISABLED,
 				"AC Detect", charger);
diff --git a/drivers/rtc/rtc-sh.c b/drivers/rtc/rtc-sh.c
index e55dc1a..6ac55fd 100644
--- a/drivers/rtc/rtc-sh.c
+++ b/drivers/rtc/rtc-sh.c
@@ -782,11 +782,11 @@ static void sh_rtc_set_irq_wake(struct device *dev, int enabled)
 	struct platform_device *pdev = to_platform_device(dev);
 	struct sh_rtc *rtc = platform_get_drvdata(pdev);
-	set_irq_wake(rtc->periodic_irq, enabled);
+	irq_set_irq_wake(rtc->periodic_irq, enabled);
 	if (rtc->carry_irq > 0) {
-		set_irq_wake(rtc->carry_irq, enabled);
-		set_irq_wake(rtc->alarm_irq, enabled);
+		irq_set_irq_wake(rtc->carry_irq, enabled);
+		irq_set_irq_wake(rtc->alarm_irq, enabled);
diff --git a/drivers/staging/brcm80211/brcmfmac/bcmsdh_linux.c b/drivers/staging/brcm80211/brcmfmac/bcmsdh_linux.c
index e3556ff..ac5bbc8 100644
--- a/drivers/staging/brcm80211/brcmfmac/bcmsdh_linux.c
+++ b/drivers/staging/brcm80211/brcmfmac/bcmsdh_linux.c
@@ -341,7 +341,7 @@ int bcmsdh_register_oob_intr(void *dhdp)
 		if (error)
 			return -ENODEV;
-		set_irq_wake(sdhcinfo->oob_irq, 1);
+		irq_set_irq_wake(sdhcinfo->oob_irq, 1);
 		sdhcinfo->oob_irq_registered = true;
@@ -352,7 +352,7 @@ void bcmsdh_unregister_oob_intr(void)
 	SDLX_MSG(("%s: Enter\n", __func__));
-	set_irq_wake(sdhcinfo->oob_irq, 0);
+	irq_set_irq_wake(sdhcinfo->oob_irq, 0);
 	disable_irq(sdhcinfo->oob_irq);	/* just in case.. */
 	free_irq(sdhcinfo->oob_irq, NULL);
 	sdhcinfo->oob_irq_registered = false;
diff --git a/drivers/staging/westbridge/astoria/arch/arm/mach-omap2/cyashalomap_kernel.c b/drivers/staging/westbridge/astoria/arch/arm/mach-omap2/cyashalomap_kernel.c
index ea9b733..21cdb06 100644
--- a/drivers/staging/westbridge/astoria/arch/arm/mach-omap2/cyashalomap_kernel.c
+++ b/drivers/staging/westbridge/astoria/arch/arm/mach-omap2/cyashalomap_kernel.c
@@ -597,7 +597,7 @@ static int cy_as_hal_configure_interrupts(void *dev_p)
 	int result;
 	int irq_pin  = AST_INT;
-	set_irq_type(OMAP_GPIO_IRQ(irq_pin), IRQ_TYPE_LEVEL_LOW);
+	irq_set_irq_type(OMAP_GPIO_IRQ(irq_pin), IRQ_TYPE_LEVEL_LOW);
 	 * for shared IRQS must provide non NULL device ptr
diff --git a/drivers/tty/hvc/hvc_xen.c b/drivers/tty/hvc/hvc_xen.c
index c35f1a7..52fdf60 100644
--- a/drivers/tty/hvc/hvc_xen.c
+++ b/drivers/tty/hvc/hvc_xen.c
@@ -178,7 +178,7 @@ static int __init xen_hvc_init(void)
 	if (xencons_irq < 0)
 		xencons_irq = 0; /* NO_IRQ */
 	else
-		set_irq_noprobe(xencons_irq);
+		irq_set_noprobe(xencons_irq);
 	hp = hvc_alloc(HVC_COOKIE, xencons_irq, ops, 256);
 	if (IS_ERR(hp))
diff --git a/drivers/tty/serial/msm_serial_hs.c b/drivers/tty/serial/msm_serial_hs.c
index 2e7fc9c..b906f11 100644
--- a/drivers/tty/serial/msm_serial_hs.c
+++ b/drivers/tty/serial/msm_serial_hs.c
@@ -1644,7 +1644,7 @@ static int __devinit msm_hs_probe(struct platform_device *pdev)
 	if (unlikely(uport->irq < 0))
 		return -ENXIO;
-	if (unlikely(set_irq_wake(uport->irq, 1)))
+	if (unlikely(irq_set_irq_wake(uport->irq, 1)))
 		return -ENXIO;
 	if (pdata == NULL || pdata->rx_wakeup_irq < 0)
@@ -1658,7 +1658,7 @@ static int __devinit msm_hs_probe(struct platform_device *pdev)
 		if (unlikely(msm_uport->rx_wakeup.irq < 0))
 			return -ENXIO;
-		if (unlikely(set_irq_wake(msm_uport->rx_wakeup.irq, 1)))
+		if (unlikely(irq_set_irq_wake(msm_uport->rx_wakeup.irq, 1)))
 			return -ENXIO;
diff --git a/drivers/usb/host/oxu210hp-hcd.c b/drivers/usb/host/oxu210hp-hcd.c
index 38193f4..44e4deb 100644
--- a/drivers/usb/host/oxu210hp-hcd.c
+++ b/drivers/usb/host/oxu210hp-hcd.c
@@ -3832,7 +3832,7 @@ static int oxu_drv_probe(struct platform_device *pdev)
 		return -EBUSY;
-	ret = set_irq_type(irq, IRQF_TRIGGER_FALLING);
+	ret = irq_set_irq_type(irq, IRQF_TRIGGER_FALLING);
 	if (ret) {
 		dev_err(&pdev->dev, "error setting irq type\n");
 		ret = -EFAULT;
diff --git a/drivers/usb/musb/tusb6010.c b/drivers/usb/musb/tusb6010.c
index 2ba3b07..c47aac4 100644
--- a/drivers/usb/musb/tusb6010.c
+++ b/drivers/usb/musb/tusb6010.c
@@ -943,7 +943,7 @@ static void tusb_musb_enable(struct musb *musb)
 	musb_writel(tbase, TUSB_INT_CTRL_CONF,
 			TUSB_INT_CTRL_CONF_INT_RELCYC(0));
-	set_irq_type(musb->nIrq, IRQ_TYPE_LEVEL_LOW);
+	irq_set_irq_type(musb->nIrq, IRQ_TYPE_LEVEL_LOW);
 	/* maybe force into the Default-A OTG state machine */
 	if (!(musb_readl(tbase, TUSB_DEV_OTG_STAT)
diff --git a/drivers/w1/masters/ds1wm.c b/drivers/w1/masters/ds1wm.c
index 95921b7..2f4fa02 100644
--- a/drivers/w1/masters/ds1wm.c
+++ b/drivers/w1/masters/ds1wm.c
@@ -368,9 +368,9 @@ static int ds1wm_probe(struct platform_device *pdev)
 	ds1wm_data->active_high = plat->active_high;
 	if (res->flags & IORESOURCE_IRQ_HIGHEDGE)
-		set_irq_type(ds1wm_data->irq, IRQ_TYPE_EDGE_RISING);
+		irq_set_irq_type(ds1wm_data->irq, IRQ_TYPE_EDGE_RISING);
 	if (res->flags & IORESOURCE_IRQ_LOWEDGE)
-		set_irq_type(ds1wm_data->irq, IRQ_TYPE_EDGE_FALLING);
+		irq_set_irq_type(ds1wm_data->irq, IRQ_TYPE_EDGE_FALLING);
 	ret = request_irq(ds1wm_data->irq, ds1wm_isr, IRQF_DISABLED,
 			  "ds1wm", ds1wm_data);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
